メインコンテンツにスキップ
Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.
必要な工具と部品
  1. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece., Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: 手順 1、 1の画像 1
    • Remove the foam speaker cover. Locate (4) T5 Torx screws and remove.
    Extend right earpiece/headband fully to remove cover more easily.
    Joey - 返信
  2. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: 手順 2、 1の画像 1
    • Remove (3) Phillips #000 screws.
    • Remove circuit board
    Ensure you have enough torque! These were very difficult to remove with jeweler’s screwdrivers.
    Joey - 返信
  3. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: 手順 3、 2の画像 1 Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: 手順 3、 2の画像 2
    • Optional, remove media buttons section by removing (3) Phillips #000 screws.
    • Cut a circular piece of foam and stuff it under the center section.
    • You are now finished! Just reassemble
終わりに
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
SYN1ST3R
メンバー登録日: 03/06/10
327 ポイント
1ガイドが承認済み
6 件のコメント
Please, can you help with silencing the low battery sound?
Houssam - 返信
OMG.. Best tutorial! I was looking at completing this and then stumbled upon your post.
The button rattle was driving me nuts!
TropiKalSTORM - 返信
Warning: this is a huge pain! I can confirm it does work though, so thank you!
Some tips:
- After removing the 4 Torx, fully extend the adjustable arm of the right earpiece/headband, it will make it easier to remove the cover
- There are very thin delicate wires connecting the PCB to the earpiece, making everything more difficult
- I could not generate enough torque with my thin stainless jewelers screwdrivers, trying as hard as I could. I recommend a large handle screwdriver. I ended up putting my jewelers screwdriver in my drill, this worked perfectly.
- I used a cut up earplug for the foam, works well, but was hard to shove into place
- Remember to put the sliding switch back into place before putting the screws in for the PCB when putting back together
Joey - 返信
Can anybody help me with the on/off (bluetooth/stick) switch? It’s the worst button ever. Function only after 5 or 6 tries. Ruining my nails every time. Is it replacable?
Peter Claassen - 返信
My kitty got a hold of my Logitech H800 and chewed on the microphone - I was wondering if there is a step on how to replace the microphone on the Logitech H800?
albwillin - 返信
Very helpful for a 'tear-down'. I have bought 4 of these S/H on eBay over the years and still like them.
I left one in a pub (they were gone when I returned the next day) and have mislaid another. I bought a third pair for my elderly father who couldn't get used to the awkward switch and indeed (due to dementure?) has worn away the tiny ridge on it. It now works using a fingernail.
My 4th pair are used daily but a couple of days ago I noticed a buzzing noise as they were charging. On picking them up, I found the micro-USB connector to be hot, so disconnected. I then realised I had just come in from wearing the headset outside in pretty bad rain, so assume there was some shorting going on around the connector? Since then, there's an intermittent connection (oxidation of contacts?), which is why I ended up here.
Have tried contact cleaner, which helps a bit, but think I need to get the soldering iron out and replace the connector.
So, thank you! :-)
renWeb - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 38
今までの合計 7,072
