メインコンテンツにスキップ
Repairing Lenovo R61i fan assembly replacement or cleaning
必要な工具と部品
  1. Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: 手順 1、 3の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: 手順 1、 3の画像 2 Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: 手順 1、 3の画像 3
    • identify the exact type of your ThinkPad
    • get the right fan assembly, in this case FRU P/N: 42W2779
    • disconnect power-supply
    • detach battery
  2. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 2、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 2、 2の画像 2
    • find all five screws with the shown symbols and unscrew them
  3. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 3、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 3、 2の画像 2
    • unscrew all the shown screws
    • These ones are tiny
    • watch the sizes of the screws
    On Step 3 on the top left, the screw to remove is actually the one next to the red circle not the one in the circle.
    MaKr0 - 返信
    Step 3 Pic 1: The red circled screws alone are not enough! All screws at the corners must be removed, or else the bezel is still screwed onto.
    porg - 返信
  4. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 4、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 4、 2の画像 2
    • remove the palm rest carefully
    • If you have a touchpad or fingerprint reader watch the cables
    • blow the dust away
  5. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 5、 3の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 5、 3の画像 2 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 5、 3の画像 3
    • lift the keyboard carefully
    • watch the cable
    • Use a spudger to detach the cable
    • lift the keyboad and leave it on the side
  6. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 6、 3の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 6、 3の画像 2 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 6、 3の画像 3
    • just for reference: images showing the keyboard-connector
  7. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 7、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 7、 2の画像 2
    • unscrew the left and right screw of the keyboard bezel and speakers
  8. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 8、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 8、 2の画像 2
    • unscrew the first two screws of the shielding
  9. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 9、 3の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 9、 3の画像 2 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 9、 3の画像 3
    • carefully lift the wireless antenna cable from the cable guide
    • unscrew the last two screws from the keyboard bezel
  10. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 10、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 10、 2の画像 2
    • watch the claws of the bezel (Sorry, no image!)
    • carefully pull out the keyboard bezel
    • flip the bezel 180°
    • watch the cables
    This is a really great procedure. My comment is very close to the one above.
    At step 10, between the first and second bullet:
    Close the screen and flip the computer over.
    Remove the two screws at the backside upper edges. this will free up the keyboard bezel. (Look at the screws pictured in step 3 circled in red.)
    On the left, the screw to remove is a the 5 o'clock position to the red circle.
    On the right, the screw to remove is at the 2 o'clock position to the red circle.
    Flip the computer back over and open it up with the screen at a 90 degree angle to the keyboard (now removed)
    In this position it will be much easier to remove the keyboard bezel.
    Thanks again, my wife was very happy to get her computer back in working order.
    James
    James - 返信
  11. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 11、 1の画像 1
    • remove the wireless antenna cable from the cable guide of the fan assembly
    • you might want to use a metal spudger to widen the cable guide if necessary
  12. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 12、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 12、 2の画像 2
    • unscrew the fist, tiny screw of the clip
    • unscrew the longer screw of the clip
    • remove the clip
  13. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 13、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 13、 2の画像 2
    • remove the shorter screw of the second clip
    • remove the longer screw of the second clip
    • remove the clip
  14. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 14、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 14、 2の画像 2
    • remove the last two screws of the fan assembly
    • detach the power cord with a spudger
  15. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 15、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 15、 2の画像 2
    • CPU with thermal grease
    • other chip with termal grease
    • carfully lift the fan assembly
    • you may need to pull a little more because of the thermal grease
  16. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 16、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 16、 2の画像 2
    • take a spudger and remove the old thermal grease
  17. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 17、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 17、 2の画像 2
    • get a paper-wiper
    • wrap the wiper around the spudger
  18. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 18、 2の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 18、 2の画像 2
    • get some alcohol on the wiper
    • clean the CPU with the wiper
    • clean the chip with the wiper
    • Ensure there is no old thermal grease left
    • Follow this guide to add new thermal paste to the CPU.
  19. Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 19、 3の画像 1 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 19、 3の画像 2 Repairing Lenovo R61i fan assembly replacement or cleaning: 手順 19、 3の画像 3
    • now place the new fan assembly
    • pay attention to the thermal grease on the backside of your new fan assembly
    • press down the CPU- and chip-connector
    • don't forget to plugin the power cable of the fan assembly
    Can you please tell me where I can get a Lenovo Thinkpad Rseries R61 Type 8918-DEG fan because I nedd to replace my old one. (I live in South Africa)
    Kevin DeKlerk - 返信
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Dennis
メンバー登録日: 01/06/13
311 ポイント
1ガイドが承認済み
2 件のコメント
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
tech4eleven - 返信
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
Ioannis Kolaxis - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 19,270
