メインコンテンツにスキップ
Repair Broken Connections in the Pyrus PY21S03211
必要な工具と部品
  1. Repair Broken Connections in the Pyrus PY21S03211, Repair Broken Connections in the Pyrus PY21S03211: 手順 1、 1の画像 1
    • Turn the video camera upside down so the bottom of the device is visible.
  2. Repair Broken Connections in the Pyrus PY21S03211: 手順 2、 2の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 2、 2の画像 2
    • Pull back the bottom tab to reveal the battery compartment.
  3. Repair Broken Connections in the Pyrus PY21S03211: 手順 3、 1の画像 1
    • Pull back the tab that is holding in the battery in place and remove the battery from the device.
  4. Repair Broken Connections in the Pyrus PY21S03211: 手順 4、 1の画像 1
    • Find the device's HDMI/TV cover.
  5. Repair Broken Connections in the Pyrus PY21S03211: 手順 5、 1の画像 1
    • Open the cover to reveal the device ports.
  6. Repair Broken Connections in the Pyrus PY21S03211: 手順 6、 2の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 6、 2の画像 2
    • Use the screwdriver to remove the 2 4mm screws from the port cover.
  7. Repair Broken Connections in the Pyrus PY21S03211: 手順 7、 3の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 7、 3の画像 2 Repair Broken Connections in the Pyrus PY21S03211: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Use the tweezers to remove the plastic port cover.
  8. Repair Broken Connections in the Pyrus PY21S03211: 手順 8、 1の画像 1
    • Open the display screen.
  9. Repair Broken Connections in the Pyrus PY21S03211: 手順 9、 3の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 9、 3の画像 2 Repair Broken Connections in the Pyrus PY21S03211: 手順 9、 3の画像 3
    • Use tweezers to carefully pull out the circular stickers to reveal the 4mm screws.
  10. Repair Broken Connections in the Pyrus PY21S03211: 手順 10、 2の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 10、 2の画像 2
    • Use the screwdriver to remove all six 4mm screws from the side of the device.
  11. Repair Broken Connections in the Pyrus PY21S03211: 手順 11、 3の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 11、 3の画像 2 Repair Broken Connections in the Pyrus PY21S03211: 手順 11、 3の画像 3
    • Use a thin plastic pick to pry off the side of the device and carefully remove the display.
  12. Repair Broken Connections in the Pyrus PY21S03211: 手順 12、 1の画像 1
    • Carefully remove the side face from the device. Avoid pulling on the white connector.
  13. Repair Broken Connections in the Pyrus PY21S03211: 手順 13、 1の画像 1
    • To remove the side face entirely, find the large white connector, flip open the grey lip with tweezers, and gently remove the white connector.
  14. Repair Broken Connections in the Pyrus PY21S03211: 手順 14、 1の画像 1
    • Find the broken wire.
  15. Repair Broken Connections in the Pyrus PY21S03211: 手順 15、 3の画像 1 Repair Broken Connections in the Pyrus PY21S03211: 手順 15、 3の画像 2 Repair Broken Connections in the Pyrus PY21S03211: 手順 15、 3の画像 3
ゴール
作成者
10人の作成者と共同で作成されました。
Danielle Hadaway
メンバー登録日: 03/31/16
255 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Giguere Spring 2016 Eastern Washington University, Team 1-5, Giguere Spring 2016人のメンバー
EWU-GIGUERE-S16S1G5
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 7
今までの合計 316
