メインコンテンツにスキップ
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement
必要な工具と部品
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement, Microphone Boom: 手順 1、 1の画像 1
    • Remove the left ear cushion by rotating it counterclockwise as far as possible.
    • Pull the cushion upwards to remove it from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 手順 2、 3の画像 1 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 手順 2、 3の画像 2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 手順 2、 3の画像 3
    • Remove the six 6 mm screws around the speaker housing.
    • Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 手順 3、 1の画像 1
    • Remove the three 6 mm screws on the inside of the ear cup.
  4. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 手順 4、 2の画像 1 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 手順 4、 2の画像 2
    • There are two wires going into the boom. One powers the LED lights and the other goes to the microphone. Each wire has two smaller ones in them.
    • Cut both wires, strip the shielding, solder the new wires together, and wrap them in electrical tape or use heat shrink. Be sure to insulate the wires from each other.
    • The two sets of wires are different colors, so you can figure out which wire powers the LEDs and which goes to the microphone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Nicholas Samokyszyn
メンバー登録日: 02/24/14
359 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G8
3 メンバー
13のガイドは作成済み
3 件のコメント
Ok, so where does one get a replacement boom mic?
stolensoulz79 - 返信
My classmate saw a pair of headphones on a
website today. He thought it was nice looking and good price. He asked me my
opinion. What do you think? Here is the link:
kobe - 返信
opinion. What do you think? Here is the link: http://menghu.ebcoo.net/product/original...
kobe - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 2,677
