メインコンテンツにスキップ
Razer Kishi Phone Connector Replacement
必要な工具と部品
  1. Razer Kishi Phone Connector Replacement, Remove the screws: 手順 1、 1の画像 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Phone Connector Replacement, Release the bottom edge clips: 手順 2、 3の画像 1 Razer Kishi Phone Connector Replacement, Release the bottom edge clips: 手順 2、 3の画像 2 Razer Kishi Phone Connector Replacement, Release the bottom edge clips: 手順 2、 3の画像 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Phone Connector Replacement, Release the side edge clips: 手順 3、 2の画像 1 Razer Kishi Phone Connector Replacement, Release the side edge clips: 手順 3、 2の画像 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Phone Connector Replacement, Release the top edge clips: 手順 4、 2の画像 1 Razer Kishi Phone Connector Replacement, Release the top edge clips: 手順 4、 2の画像 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Phone Connector Replacement: 手順 5、 3の画像 1 Razer Kishi Phone Connector Replacement: 手順 5、 3の画像 2 Razer Kishi Phone Connector Replacement: 手順 5、 3の画像 3
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: 手順 6、 3の画像 1 Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: 手順 6、 3の画像 2 Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: 手順 6、 3の画像 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Phone Connector Replacement, Remove the screws: 手順 7、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
  8. Razer Kishi Phone Connector Replacement, Remove the breakout board: 手順 8、 3の画像 1 Razer Kishi Phone Connector Replacement, Remove the breakout board: 手順 8、 3の画像 2 Razer Kishi Phone Connector Replacement, Remove the breakout board: 手順 8、 3の画像 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
  9. Razer Kishi Phone Connector Replacement, Remove the screws: 手順 9、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
  10. Razer Kishi Phone Connector Replacement, Remove the trigger: 手順 10、 2の画像 1 Razer Kishi Phone Connector Replacement, Remove the trigger: 手順 10、 2の画像 2
    • Remove the shoulder trigger.
  11. Razer Kishi Phone Connector Replacement, Lift the shoulder button board: 手順 11、 2の画像 1 Razer Kishi Phone Connector Replacement, Lift the shoulder button board: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of blunt nose tweezers to lift out the shoulder button board.
  12. Razer Kishi Phone Connector Replacement, Remove the screws: 手順 12、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
  13. Razer Kishi Phone Connector Replacement, Remove the board: 手順 13、 2の画像 1 Razer Kishi Phone Connector Replacement, Remove the board: 手順 13、 2の画像 2
    • Pull the mainboard straight out of the frame to remove it.
  14. Razer Kishi Phone Connector Replacement, Unfasten screws: 手順 14、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four 5.7 mm screws securing the phone bracket.
  15. Razer Kishi Phone Connector Replacement, Remove the phone bracket: 手順 15、 2の画像 1 Razer Kishi Phone Connector Replacement, Remove the phone bracket: 手順 15、 2の画像 2
    • Remove the phone bracket.
  16. Razer Kishi Phone Connector Replacement, Remove the rubber phone pad: 手順 16、 2の画像 1 Razer Kishi Phone Connector Replacement, Remove the rubber phone pad: 手順 16、 2の画像 2
    • Use your fingers to lift the rubber phone pad out sideways.
  17. Razer Kishi Phone Connector Replacement, Unfasten the screws: 手順 17、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the two 4.6 mm screws securing the phone connector.
  18. Razer Kishi Phone Connector Replacement: 手順 18、 3の画像 1 Razer Kishi Phone Connector Replacement: 手順 18、 3の画像 2 Razer Kishi Phone Connector Replacement: 手順 18、 3の画像 3
    • Thread the phone connector through its opening in the side of the controller.
    • Remove the phone connector.
終わりに
2 の人々がこのガイドを完成させました。
Adriana Zwink
メンバー登録日: 12/18/19
50,878 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,077のガイドは作成済み
2 件のコメント
Where can I find this c type connector?
eric nelson - 返信
Is it exactly the same on the kishi v2 or is it different? If yes how? And where can i buy that usb c port thats made for the controller to output the inputs?
HypeShadow Duck - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 55
今までの合計 3,351
