メインコンテンツにスキップ
Razer Kishi Direction Pad Replacement
必要な工具と部品
  1. Razer Kishi Direction Pad Replacement, Remove the screws: 手順 1、 1の画像 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Direction Pad Replacement, Release the bottom edge clips: 手順 2、 3の画像 1 Razer Kishi Direction Pad Replacement, Release the bottom edge clips: 手順 2、 3の画像 2 Razer Kishi Direction Pad Replacement, Release the bottom edge clips: 手順 2、 3の画像 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Direction Pad Replacement, Release the side edge clips: 手順 3、 2の画像 1 Razer Kishi Direction Pad Replacement, Release the side edge clips: 手順 3、 2の画像 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Direction Pad Replacement, Release the top edge clips: 手順 4、 2の画像 1 Razer Kishi Direction Pad Replacement, Release the top edge clips: 手順 4、 2の画像 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Direction Pad Replacement: 手順 5、 3の画像 1 Razer Kishi Direction Pad Replacement: 手順 5、 3の画像 2 Razer Kishi Direction Pad Replacement: 手順 5、 3の画像 3
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Direction Pad Replacement, Disconnect the interconnect cable: 手順 6、 3の画像 1 Razer Kishi Direction Pad Replacement, Disconnect the interconnect cable: 手順 6、 3の画像 2 Razer Kishi Direction Pad Replacement, Disconnect the interconnect cable: 手順 6、 3の画像 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Direction Pad Replacement, Remove the screws: 手順 7、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
  8. Razer Kishi Direction Pad Replacement, Remove the breakout board: 手順 8、 3の画像 1 Razer Kishi Direction Pad Replacement, Remove the breakout board: 手順 8、 3の画像 2 Razer Kishi Direction Pad Replacement, Remove the breakout board: 手順 8、 3の画像 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
  9. Razer Kishi Direction Pad Replacement, Remove the screws: 手順 9、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
  10. Razer Kishi Direction Pad Replacement, Remove the trigger: 手順 10、 2の画像 1 Razer Kishi Direction Pad Replacement, Remove the trigger: 手順 10、 2の画像 2
    • Remove the shoulder trigger.
  11. Razer Kishi Direction Pad Replacement, Lift the shoulder button board: 手順 11、 2の画像 1 Razer Kishi Direction Pad Replacement, Lift the shoulder button board: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of blunt nose tweezers to lift out the shoulder button board.
  12. Razer Kishi Direction Pad Replacement, Remove the screws: 手順 12、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
  13. Razer Kishi Direction Pad Replacement, Remove the board: 手順 13、 2の画像 1 Razer Kishi Direction Pad Replacement, Remove the board: 手順 13、 2の画像 2
    • Pull the mainboard straight out of the frame to remove it.
  14. Razer Kishi Direction Pad Replacement, Remove the rubber cover: 手順 14、 3の画像 1 Razer Kishi Direction Pad Replacement, Remove the rubber cover: 手順 14、 3の画像 2 Razer Kishi Direction Pad Replacement, Remove the rubber cover: 手順 14、 3の画像 3
    • Remove the rubber cover that is attached on top of the direction pad.
  15. Razer Kishi Direction Pad Replacement, Remove the direction pad: 手順 15、 3の画像 1 Razer Kishi Direction Pad Replacement, Remove the direction pad: 手順 15、 3の画像 2 Razer Kishi Direction Pad Replacement, Remove the direction pad: 手順 15、 3の画像 3
    • Remove the direction pad.
終わりに
Adriana Zwink
メンバー登録日: 12/18/19
50,416 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
17,895のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 27
今までの合計 1,470
