はじめに
After extensive use or a large period of time, the Razer Deathadder Essential’s (Model Number: RZ01-0254) mouse buttons may begin to double-click. Double-clicking is when the user only gives one input but receives 2 outputs.
In this guide, I will show you how to replace the buttons so that they will be brand new!
Before getting started, if you are unfamiliar with how to solder and desolder components from a motherboard, please read this guide.
必要な工具と部品
Use a spudger or opening tool to remove the top skates from the mouse.
Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
この手順で使用する道具:Desoldering Pump$3.99
Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
5 の人々がこのガイドを完成させました。
