メインコンテンツにスキップ
Razer Blackwidow Chroma Key Switch Replacement
必要な工具と部品
  1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: 手順 1、 2の画像 1 Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: 手順 1、 2の画像 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: 手順 2、 2の画像 1 Razer Blackwidow Chroma Key Switch Replacement, Front Panel: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: 手順 3、 2の画像 1 Razer Blackwidow Chroma Key Switch Replacement, Back Panel: 手順 3、 2の画像 2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 手順 4、 3の画像 1 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 手順 4、 3の画像 2 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 手順 4、 3の画像 3
    • De-solder the anchor of each key that you desire to replace with a soldering iron.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the key switch once the de-soldering is complete.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Annika Grace Ford
メンバー登録日: 02/18/21
394 ポイント
3のガイドは作成済み
3 件のコメント
hello where to buy the switches for this keyboard?
ninja636 - 返信
I've seen Razer Green Switches (the ones for the Blackwidow) with RGB lighting available for sale on eBay.
I hope that helps!
Matt Von Grimm -
Hi Annika, I have razer black widow chroma overwatch edition, Is gateron optical switch compatible with it?
Jaydeep Parmar - 返信
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 71
過去 30 日: 284
今までの合計 21,355
