はじめに
The Pyle Astro’s screen is comprised of three layers, the external touch panel, the capacitive touch screen overlay, and the tablet’s LCD. Use this guide to replace your tablet’s LCD.
必要な工具と部品
De-solder the two wires (see two red arrows in image) that connect the PCB to the LCD panel.
この手順で使用する道具:Plastic Cards$2.99
Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
Install the new LCD panel and solder all the connections back into place.
もう少しです!
終わりに
