はじめに
This guide shows how to replace the camera module for the Protocol Videodrone AP Drone. This is a slightly lengthy process as you will have to disassemble most of your drone. The camera module itself is both the sensor housing + the circuit board connected it it. You will only have to replace the circuit board, as the sensor housing is attached to it.
Remember to use the included #0 Phillips head screwdriver that came with your drone.
A soldering iron is required, so keep one ready.
You will also need a replacement camera module.
必要な工具と部品
