メインコンテンツにスキップ
Protocol TerraCopter EVO Left & Right Joystick Replacement
必要な工具と部品
  1. Protocol TerraCopter EVO Left & Right Joystick Replacement, Controller's battery: 手順 1、 2の画像 1 Protocol TerraCopter EVO Left & Right Joystick Replacement, Controller's battery: 手順 1、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
    • Remove the battery cover from the controller.
  2. Protocol TerraCopter EVO Left & Right Joystick Replacement: 手順 2、 1の画像 1
    • Remove all of four of the AA batteries from the controller.
  3. 注意: 手順 3-4 は、作業進行中としてマークされている ガイド から引用されています。
    Protocol TerraCopter EVO Left & Right Joystick Replacement, Protocol TerraCopter EVO Controller Opening: 手順 3、 1の画像 1
    • Note: the four Phillips screws on the rear panel are a millimeter longer than the two screws near the antenna and the two screws on the handle.
    • Orientate the controller to where the battery compartment is facing upwards.
    • Remove the four 5mm and four 4mm Phillips #1 screws from the case.
  4. Protocol TerraCopter EVO Left & Right Joystick Replacement: 手順 4、 1の画像 1
    • Since the battery wires are still attached, carefully move the rear panel down to expose the motherboard.
  5. Protocol TerraCopter EVO Left & Right Joystick Replacement, Left & Right Joystick: 手順 5、 1の画像 1
    • Remove the eight 5mm Phillips #1 screws from the motherboard.
  6. Protocol TerraCopter EVO Left & Right Joystick Replacement: 手順 6、 2の画像 1 Protocol TerraCopter EVO Left & Right Joystick Replacement: 手順 6、 2の画像 2
    • After removing the screws, orientate the motherboard to where the side with the black joysticks face upwards.
    • Pull the black plastic joysticks from the motherboard, out of their their assembly.
  7. Protocol TerraCopter EVO Left & Right Joystick Replacement: 手順 7、 1の画像 1
    • Once the joysticks are removed, orientate the motherboard to where the green side is facing upwards.
    • On the green side of the motherboard, locate the two sets of ten pin arrays that hold the joystick assembly to the motherboard.
  8. Protocol TerraCopter EVO Left & Right Joystick Replacement: 手順 8、 1の画像 1
    • Melt the existing solder points on the pin arrays with a soldering iron and lift the joystick assemblies from their location on the motherboard.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
終わりに
作成者
1人の作成者と共同作成されました。
Derek Vande
メンバー登録日: 10/03/19
244 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 13
今までの合計 265
