メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ProntoTec Axius Motherboard Replacement
必要な工具と部品
    1. ProntoTec Axius Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      FixBotに聞いてみる
      コメントを追加
    2. ProntoTec Axius Motherboard Replacement: 手順 2、 1の画像 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      FixBotに聞いてみる
      コメントを追加
    3. ProntoTec Axius Motherboard Replacement: 手順 3、 1の画像 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      FixBotに聞いてみる
      コメントを追加
    4. ProntoTec Axius Motherboard Replacement: 手順 4、 2の画像 1 ProntoTec Axius Motherboard Replacement: 手順 4、 2の画像 2
      • Remove only the yellow tape that touches the motherboard
      • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    5. ProntoTec Axius Motherboard Replacement: 手順 5、 3の画像 1 ProntoTec Axius Motherboard Replacement: 手順 5、 3の画像 2 ProntoTec Axius Motherboard Replacement: 手順 5、 3の画像 3
      • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
      • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
      FixBotに聞いてみる
      コメントを追加
    6. ProntoTec Axius Motherboard Replacement: 手順 6、 2の画像 1 ProntoTec Axius Motherboard Replacement: 手順 6、 2の画像 2
      • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
      • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
      • Use pliers to pull the wire from the board
      FixBotに聞いてみる
      コメントを追加
    7. ProntoTec Axius Motherboard Replacement: 手順 7、 2の画像 1 ProntoTec Axius Motherboard Replacement: 手順 7、 2の画像 2
      • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
      FixBotに聞いてみる
      コメントを追加
    8. ProntoTec Axius Motherboard Replacement: 手順 8、 3の画像 1 ProntoTec Axius Motherboard Replacement: 手順 8、 3の画像 2 ProntoTec Axius Motherboard Replacement: 手順 8、 3の画像 3
      • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
      • Gently pull and remove the ribbon cables from the motherboard
      FixBotに聞いてみる
      コメントを追加
    9. ProntoTec Axius Motherboard Replacement: 手順 9、 2の画像 1 ProntoTec Axius Motherboard Replacement: 手順 9、 2の画像 2
      • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Estelle Hatem
メンバー登録日: 10/20/16
156 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G3
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 32
今までの合計 637
