メインコンテンツにスキップ
Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement
必要な工具と部品
  1. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement, Presto Flipside Belgian Waffle Maker Thermal Fuse: 手順 1、 1の画像 1
    • Remove the four 0.7 mm screws that keep the cover of the wiring and thermal fuse in place using a #2 Phillips-head screwdriver.
    • The thermal fuse is located under the cover on which the handle points to the right.
  2. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 2、 3の画像 1 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 2、 3の画像 2 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 2、 3の画像 3
    • Pull the handle up and away from the waffle iron to remove the cover and expose the circuit.
  3. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 3、 3の画像 1 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 3、 3の画像 2 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 3、 3の画像 3
    • Remove the clasp holding the fuse in place using the #2 Phillips screwdriver.
    • Pull the clasp off of the thermal fuse.
  4. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 4、 1の画像 1
    • Cut through the insulation to expose one end of the thermal fuse using a pair of scissors.
  5. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 5、 3の画像 1 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 5、 3の画像 2 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 5、 3の画像 3
    • Use two pairs of needle-nosed pliers to pull the fuse out of the conduction bearing. Firmly grasp one end of the thermal fuse with one set of pliers and the conduction bearing it is connected to and pull them apart.
    • This requires a strong pull.
    • Remove the insulation from the thermal fuse and pull the other end of the thermal fuse out of the circuit in the same way.
  6. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 6、 3の画像 1 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 6、 3の画像 2 Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 6、 3の画像 3
    • Plug the soldering iron in and allow it to heat up.
    • Once the soldering iron has reached an acceptable heat, use the solder to connect the new thermal fuse to the conduction bearing.
    • Slide a new heat shrink wire insulator over the new fuse and solder the other side of the fuse to the other conduction bearing.
    • Refer to this soldering guide for helpful pointers.
  7. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 7、 1の画像 1
    • Use a hair dryer or heat gun to shrink the insulator to the shape of the new thermal fuse.
  8. Presto Flipside Belgian Waffle Maker Thermal Fuse Replacement: 手順 8、 1の画像 1
    • Secure the thermal fuse by reattaching the clasp and screwing it into place.
終わりに
To reassemble your device, follow steps 1 and 2 in reverse order.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Lillian Fite
メンバー登録日: 02/20/19
181 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G3, Baddour Spring 2019 University of Memphis, Team S2-G3, Baddour Spring 2019人のメンバー
UM-BADDOUR-S19S2G3
2 メンバー
1のガイドは作成済み
4 件のコメント
Out of curiosity how are the heating elements wired in this waffle maker? Are they in series or parallel?
Ess - 返信
Won't the solder melt when you turn on the waffle iron? Duh
sals57chevy - 返信
Yeah, I think you need to clamp or spot-weld?
Jefferson Malone -
This instruction should be removed!
The Thermal fuse is likely 240C which is 460F.
This is close to the melting point of solder.
The joint needs a mechanical connection.
Run-of-the-mill plastic shrink tube is in no way a replacement for woven fiberglass electrical insulating sleeves.
Seth T - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 40
今までの合計 2,998
