メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G4 Titanium Mercury Logic Board Replacement
必要な工具と部品
  1. PowerBook G4 Titanium Mercury Logic Board Replacement, Keyboard: 手順 1、 1の画像 1
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    FixBotに聞いてみる
  2. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 2、 1の画像 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    FixBotに聞いてみる
  3. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 3、 1の画像 1
    • Your laptop should look approximately like this.
    FixBotに聞いてみる
  4. PowerBook G4 Titanium Mercury Logic Board Replacement, RAM: 手順 4、 1の画像 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    FixBotに聞いてみる
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
    FixBotに聞いてみる
  5. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 6、 1の画像 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    FixBotに聞いてみる
  6. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 7、 1の画像 1
    FixBotに聞いてみる
  7. PowerBook G4 Titanium Mercury Logic Board Replacement, Airport Card: 手順 8、 1の画像 1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    FixBotに聞いてみる
  8. PowerBook G4 Titanium Mercury Logic Board Replacement, Hard Drive: 手順 9、 1の画像 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    FixBotに聞いてみる
  9. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 10、 1の画像 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    FixBotに聞いてみる
  10. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 11、 1の画像 1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    FixBotに聞いてみる
  11. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 12、 1の画像 1
    FixBotに聞いてみる
  12. PowerBook G4 Titanium Mercury Logic Board Replacement, DVD Drive: 手順 13、 1の画像 1
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
    • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
    FixBotに聞いてみる
  13. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 14、 1の画像 1
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    FixBotに聞いてみる
  14. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 15、 1の画像 1
    • Turn the G4 over.
    • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
    FixBotに聞いてみる
  15. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 16、 1の画像 1
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    FixBotに聞いてみる
  16. PowerBook G4 Titanium Mercury Logic Board Replacement, Modem: 手順 17、 1の画像 1
    • Turn the G4 over.
    • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
    FixBotに聞いてみる
  17. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 18、 1の画像 1
    • Lift the modem out by pulling up and to the right.
    • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
    FixBotに聞いてみる
  18. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 19、 1の画像 1
    • Disconnect the connector cable from the modem.
    FixBotに聞いてみる
  19. PowerBook G4 Titanium Mercury Logic Board Replacement, Logic Board: 手順 20、 1の画像 1
    • Turn the G4 over and rest it on a soft cloth.
    • Disconnect the multicolored fan connector and battery connector from the logic board.
    • Disconnect the orange PC card cage connector from the logic board.
    FixBotに聞いてみる
  20. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 21、 1の画像 1
    • Remove the single T8 Torx screw located next to the PC Card cage.
    FixBotに聞いてみる
  21. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 22、 1の画像 1
    • Turn the G4 over.
    • Remove the two T8 Torx screws from the middle of the logic board.
    FixBotに聞いてみる
  22. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 23、 1の画像 1
    • Disconnect the four indicated connectors from the logic board, removing tape as necessary.
    FixBotに聞いてみる
  23. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 24、 1の画像 1
    • Carefully lift the logic board up and pull it away from you. The logic board may catch on the back panel ports liner. If this occurs, use a spudger or non-metal tool to free the logic board.
    • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
    • Remove the logic board from the computer.
    FixBotに聞いてみる
  24. PowerBook G4 Titanium Mercury Logic Board Replacement: 手順 25、 1の画像 1
    FixBotに聞いてみる
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 88
今までの合計 15,732
