メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G4 Titanium Mercury DVD Drive Replacement
必要な工具と部品
    1. PowerBook G4 Titanium Mercury DVD Drive Replacement, Keyboard: 手順 1、 1の画像 1
      • Remove the battery.
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 2、 1の画像 1
      • Rest the keyboard face down on the trackpad area.
      • Disconnect the keyboard connector from the logic board.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 3、 1の画像 1
      • Your laptop should look approximately like this.
      FixBotに聞いてみる
      コメントを追加
      • Turn the G4 over.
      • Remove the eight Phillips screws from the lower case.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 5、 1の画像 1
      • Using your thumbs, slide the lower case away from you.
      • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 6、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium Mercury DVD Drive Replacement, DVD Drive: 手順 7、 1の画像 1
      • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
      • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 8、 1の画像 1
      • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
      • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 9、 1の画像 1
      • Turn the G4 over.
      • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G4 Titanium Mercury DVD Drive Replacement: 手順 10、 1の画像 1
      • Remove the DVD drive by lifting the right edge up and out of the computer.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 35
今までの合計 12,858
