メインコンテンツにスキップ
PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement
必要な工具と部品
  1. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement, Upper Case: 手順 2、 1の画像 1
    • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
  3. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 3、 1の画像 1
    • Remove the memory compartment cover.
    • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
    I had 7mm screws here instead of 12mm. Did without them till later.
    gepkes - 返信
    I have an Aluminum PowerBook G4 1.67Ghz since 2006.
    3/4 (from bottom to top) of the LCD becomes either black or is jumbled each time I turn on the MAC or move the screen. I need to press the LCD at several locations in order for this problem to go.... any advice ?
    Polanskiman - 返信
    re: Polanskiman; this is usually caused by a loose ribbon connector on the rear of the LCD. Open up the display, remove the LCD, lay flat and re-connect the ribbon plug.
    aaiverson - 返信
  4. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 4、 1の画像 1
    • Rotate the computer 90 degrees clockwise so the power receptacle faces you.
    • Remove the three 3 mm Phillips screws along the edge of the lower case.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
  5. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 5、 1の画像 1
    • Turn the computer 90 degrees clockwise so the hinge faces you.
    • Remove the lower 5 mm Phillips screw on each side of the hinge (two total).
  6. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 6、 1の画像 1
    • Rotate the computer 90 degrees clockwise so the ports face you.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
  7. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 7、 1の画像 1
    • Turn the computer over and open the display.
    • Remove the two 4.2 mm long, 1.5 mm hex screws at the top corners of the upper case (two total).
    • A T6 Torx driver will work, but repeated use will strip the screws.
  8. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 8、 1の画像 1
    • Grasp the back corners of the upper case and pull up.
    • Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 9、 1の画像 1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
    First of all, awesome guide. I am using it in July 2015, and there is no way I could have successfully navigate the typical Apple laptop Rubik's cube of Powerbook maintenance.
    Second, there is a REAL trick to removing the upper case here, and it involves knowing what those stupid internal metal catches look like so you can free them without folding your aluminum case into a pretzel.
    WildBill - 返信
  10. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 10、 1の画像 1
    • Remove the amber tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board by pulling up on the connector.
    • Remove the upper case from the computer.
    in my g4 there is also a big transparent ribbon (for keyboard?), to the right of the amber trackpad ribbon, that i disconnected before removing case cover.
    [deleted] - 返信
    re: ykuwabara; this is due to the differences between the Model A1095 (yours) and the newer A1138 (illustrated here). The A1138 combines the keyboard and trackpad signals into one cable.
    aaiverson - 返信
  11. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement, PRAM Battery: 手順 11、 1の画像 1
    • Use a spudger to pry up the PRAM battery from the optical drive.
  12. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 12、 1の画像 1
    • Disconnect the PRAM battery cable from the logic board and remove the PRAM battery.
    • Remove tape as necessary.
    This step is unnecessary, the drive can be removed without disconnecting the PRAM battery. Simply fold the battery back onto the logic board.
    Jeff Johnson - 返信
  13. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement, Optical Drive: 手順 13、 1の画像 1
    • Remove the short black Phillips screw from the front right corner of the optical drive.
    • Remove the three longer silver Phillips screws from the retaining bracket on the left side of the optical drive.
  14. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 14、 1の画像 1
    • Remove the retaining bracket.
  15. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 15、 1の画像 1
    • Disconnect the large black connector from the logic board.
  16. PowerBook G4 Aluminum 15" 1.67 GHz Optical Drive Replacement: 手順 16、 1の画像 1
    • Lift the optical drive out of the computer from the side with the connector on it.
    • The optical drive is held in place by an alignment peg in the lower left corner.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Depending on the drive you purchase you may need to remove 2 brackets from old drive and attach to new drive in order to secure it in the case.
    jcostagl - 返信
終わりに
20 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Andrew Bookholt
586,715 ポイント
619のガイドは作成済み
2 件のコメント
This otherwise excellent guide omits the cmos battery which is stuck to to optical drive. I did not need to disconnect the top tray, I just stood it up against the display. I was fitting a slightly older drive on which the right hand bracket was a different design.I used the bracket from the original drive. Ifixit rocks!
harwood - 返信
I installed a sata hdd caddy in my Powerbook and thought it did work it seemed to run slow. Might have been faster with a ssd... Good that I went back in my Powerbook since the right usb cable was loose and not working.
georgevp1 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 15,743
