この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
はじめに
最大12.5mmまでのハードドライブを装着できます。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Place enough pressure on the upper case to allow you to slide a tool just within the seam between upper case and lower case as shown in the picture. A dentist's hook, push pin, or similar tool will work.
Delicately slip the tip of your tool behind the silver metal latch and pull it forward while pulling up on the case. This may take some effort.
Alternatively, you can free the clasp with a small flathead screwdriver through the CD slot. The clasp is 1-3/16 in (3cm) from the left side of the slot. Use the screwdriver to lift out (or press back) the felt lining; then use the screwdriver to pull the clasp (shiny metal) forward to free it from the catch behind it (dull metal).
この手順は未翻訳です。 翻訳を手伝う。
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Rotate the upper case up and toward the screen, so that the upper case rests against it.
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
172 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
71%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
添付文書
8 件のコメント
Step 9-10 : I found the instructions on releasing the front latch not very helpful (at least I did not succeed) following these steps). However I found on line the official Apple disassembly manual whci directs you to do the following : lift the keyboard assembly from the back up to 45 degrees and this will (and DOES) release the front latches when you gently wiggle the keyboard assembly left and right. When you do that you can indeed SEE where the latches are and it really helps. No prying tools necessary. Good luck.
An excellent tutorial. I needed to remove the HDD for destruction prior to transferring the system to our surplus warehouse. I agree with the comment above that the front is difficult to remove, but was able to disconnect easily enough using a small dental pick. Thank you for the breakdown.
I really appreciated this photo and text info page. My powerbook was making a grinding sound. When I opened it up it turned out to be the hard drive. I installed a solid state drive, but I am having issues installing the OS.
Some things I found that might be helpful to others....
1) I could never boot my powerbook to a CD by holding down the "C". Key. However I was able to boot many time by holding down the Option key.
2) I never did pull out the two cables in step 12 and 13. All I did was lift up the keyboard and lay it up next to the screen with out ever taking the two cable off the power book. I had more then enough room to pull the old hard drive and install the new one.
3) Try holding down the Option key on boot if you can not boot to a CD. It works for me.
Thank you who ever you are for posting this web page. It was extremely helpful.
Great instructions. The comment that the keyboard and trackpad cables don’t need to be disconnected is spot on. Just lift up the top case and tape it to the screen, and there is plenty of room to work on the hard drive.
My only disagreement is with the difficulty rating. I’d rate it as medium, rather than difficult. I’ve taken apart a 2010 Mac mini recently to swap in an SSD - THAT is DIFFICULT. This is easy in comparison - mostly just removing and keeping track of lots of tiny screws. On the other hand, the previous owner had dropped it a few times, denting the case, so the only hard part involving the release of a not-visible latch wasn’t an issue for me as the dented case had caused the latch to become ineffective.
