メインコンテンツにスキップ
Power and 3.5 mm Audio Adapter Jacks Replacement
必要な工具と部品
  1. Power and 3.5 mm Audio Adapter Jacks Replacement, Exterior Housing: 手順 1、 3の画像 1 Power and 3.5 mm Audio Adapter Jacks Replacement, Exterior Housing: 手順 1、 3の画像 2 Power and 3.5 mm Audio Adapter Jacks Replacement, Exterior Housing: 手順 1、 3の画像 3
    この手順で使用する道具:
    iOpener
    $19.99
    購入する
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
  2. Power and 3.5 mm Audio Adapter Jacks Replacement, Lower Half Casing: 手順 2、 3の画像 1 Power and 3.5 mm Audio Adapter Jacks Replacement, Lower Half Casing: 手順 2、 3の画像 2 Power and 3.5 mm Audio Adapter Jacks Replacement, Lower Half Casing: 手順 2、 3の画像 3
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
  3. Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 3、 3の画像 1 Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 3、 3の画像 2 Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 3、 3の画像 3
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
  4. Power and 3.5 mm Audio Adapter Jacks Replacement, Power and 3.5 mm Audio Adapter Jacks: 手順 4、 1の画像 1
    • Firmly and cautiously unplug the two white 3-pin connectors from the printed circuit board.
  5. Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 5、 3の画像 1 Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 5、 3の画像 2 Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 5、 3の画像 3
    • Remove the two 5mm screws holding the power and 3.5mm jack PCB onto the rest of the device; you will need a Phillips #1 driver to do this.
    • Lift the PCB away from the rest of the device.
  6. Power and 3.5 mm Audio Adapter Jacks Replacement: 手順 6、 1の画像 1
    • Desolder the two black and two red cables from the board.
    • These wires will need to be soldered to the replacement board when reassembling the device.
    • You can refer to iFixit's guide or this informative video for more information on soldering.
終わりに
作成者
4人の作成者と共同で作成されました。
Jerrell
メンバー登録日: 04/23/14
730 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G50
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 19
今までの合計 2,842
