メインコンテンツにスキップ
Power Mac G5 Processor and Cooling Unit Replacement
必要な工具と部品
  1. Power Mac G5 Processor and Cooling Unit Replacement, Side Panel: 手順 1、 1の画像 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Processor and Cooling Unit Replacement: 手順 2、 1の画像 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Processor and Cooling Unit Replacement: 手順 3、 2の画像 1 Power Mac G5 Processor and Cooling Unit Replacement: 手順 3、 2の画像 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Processor and Cooling Unit Replacement: 手順 4、 3の画像 1 Power Mac G5 Processor and Cooling Unit Replacement: 手順 4、 3の画像 2 Power Mac G5 Processor and Cooling Unit Replacement: 手順 4、 3の画像 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Processor and Cooling Unit Replacement, Front Fan Assembly: 手順 5、 1の画像 1
    • Locate the front fan assembly.
  6. Power Mac G5 Processor and Cooling Unit Replacement: 手順 6、 1の画像 1
    • Pull the fan assembly out; it should slide out easily.
  7. Power Mac G5 Processor and Cooling Unit Replacement, Bottom Right Cooling Fan Unit: 手順 7、 2の画像 1 Power Mac G5 Processor and Cooling Unit Replacement, Bottom Right Cooling Fan Unit: 手順 7、 2の画像 2
    • The cooling fan unit is located on the bottom right of the Apple G5 Desktop.
  8. Power Mac G5 Processor and Cooling Unit Replacement: 手順 8、 2の画像 1 Power Mac G5 Processor and Cooling Unit Replacement: 手順 8、 2の画像 2
    • Remove the G5 metal cover from the processing/cooling unit of the computer. NOTE: Apple inserted a rather fragile plastic pin that inserts through the top divider shield and clips into a tab on the hidden ledge of this CPU shield. Removing this pin, certainly voided Mac's warranty - but more appropriate for now, voids most after-market insurance plans. A replacement pin (new) is hard to get ahold of, and very few are talented and patient enough to remove this pin without damaging it. Just something to keep in mind. If you have no warranty any longer or don't care, please continue...
    • Pull the metal plate to the left and outward to remove the plate from the processing/cooling unit.
  9. Power Mac G5 Processor and Cooling Unit Replacement: 手順 9、 1の画像 1
    • Locate the bottom right fan.
  10. Power Mac G5 Processor and Cooling Unit Replacement: 手順 10、 1の画像 1
    • Unplug the fan's power cable from the upper rightmost corner of the motherboard (connection J45). If there is a video card in place, carefully pull the cable plug down between the back edge of the video card and the motherboard. Note, the photo shows the unplugged cable and the area it plugs into outlined in yellow. No video card is shown in this photo.
  11. Power Mac G5 Processor and Cooling Unit Replacement: 手順 11、 2の画像 1 Power Mac G5 Processor and Cooling Unit Replacement: 手順 11、 2の画像 2
    • Locate the tabs on the fan unit.
    • While pushing in on the tabs, highlighted in yellow, pull the fan back towards the cooling unit.
  12. Power Mac G5 Processor and Cooling Unit Replacement: 手順 12、 2の画像 1 Power Mac G5 Processor and Cooling Unit Replacement: 手順 12、 2の画像 2
    • After the latches are out, pull the fan out.
  13. Power Mac G5 Processor and Cooling Unit Replacement: 手順 13、 1の画像 1
    • After removal of the bottom right fan the space should look like this.
  14. Power Mac G5 Processor and Cooling Unit Replacement, Processor and Cooling Unit: 手順 14、 1の画像 1
    • Locate the Cooling Unit on the Apple G5.
    • Put the CPU case on its back with the opening facing up to make the next steps easier.
  15. Power Mac G5 Processor and Cooling Unit Replacement: 手順 15、 3の画像 1 Power Mac G5 Processor and Cooling Unit Replacement: 手順 15、 3の画像 2 Power Mac G5 Processor and Cooling Unit Replacement: 手順 15、 3の画像 3
    • Unscrew 8 T10 screws from the cooling unit. NOTE: these screws are acctually allen keys. The prefered tool will be long handled allen keys. t10 are 2.74mm (closest allen key is 2.5 or 3mm) and t15 are 3.27mm(closest allen key is 3mm and 4mm). You may strip your tool or the actual screws themselves. Use a set of high quality long handled allen keys.
    • The screws are somewhat hidden, so they cannot be see in the picture.
    • To visualize the location of the screws look 3 steps ahead.
    • The screws will loosen but will not come out, they are designed to loosen the unit, but remain in place.
    • The last two images show another version of the LCS (out of the computer) in the G5 with off-center views to show the 8 screw holes.
  16. Power Mac G5 Processor and Cooling Unit Replacement: 手順 16、 1の画像 1
    • Pull the cooling/processing unit straight up to prevent damage to logic board
    • This will require some effort and should be done with caution to avoid damage.
    • The sleeves around the 6 screws may hold it in, if so just take a pair of needle nose pliers and gently squeeze the sleeves until it releases.
    • Pull the bottom, then side towards the bottom of the CPU case, first to move around the bottom coolant sleeve around the heat sinking bracket. *heat sinking bracket not in picture*
  17. Power Mac G5 Processor and Cooling Unit Replacement: 手順 17、 1の画像 1
    • Disconnect the cable.
  18. Power Mac G5 Processor and Cooling Unit Replacement: 手順 18、 1の画像 1
    • NOTE: Here are the standoffs without the cooling unit installed to make it easier to understand where the screws are located. Remove the bottom 2 standoffs so it is easier to remove the power supply.
    • Check the pin connections for any damage. All the pins highlighted in yellow should appear straight up and not appear bent. DON'T TOUCH THE PINS. A bent pin will result in your computer not powering on.
終わりに
58 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Nolan
メンバー登録日: 01/13/10
2,250 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S5G8
7 メンバー
30のガイドは作成済み
5件のガイドコメント
This is a great teardown/guide! you should email one of the iFixit staff members and have them post it so the whole community can see it!
Chris Green - 返信
I have a different cooling apparatus in my Quad Core than the one pictured here. It has a wider radiator on the left side and two black pumps on the right side. The pumps are elevated away from the CPUs. Nearest the CPUS is a grey plastic covering with Cooligy printed on it.
I can only find 6 of the 8 screws mentioned in STEP 15. The unit will not come out. If the 2 remaining screws are as pictured in STEP 18, then they would be directly under my radiator. Do I need to remove that too?
jaesonk - 返信
Kaesong,
I have the same problem with a G5 Dual 2.5 Quad core (version 2) LCS. I am about to loose it. Did you ever find out how to get the LCS off the mother or logic board? Please let me know.
Mark
castsmooth@yahoo.com
Mark Stevens - 返信
On the Delphi / Cooligy model the hex ball end screws behind radiator have got to come out following the crossbar there are 2 10 T that are flathead with no washer note that because they have to go back same way. Do not forget the Power Buss for processor the powerleads have to be disconnected because processor board is under them. The Delphi / Cooligy has 2 pumps and was the least successful implementation of the LCS. Panasonic later made one which was great and sold as a replacement for the Delphi / Cooligy for a replacement (THE BEST IMPLMENTATION) of the LCS. Hope this help battling on of these beast myself.....
Edward Johnson - 返信
@Edward, you are 100% mistaken about the Panasonic and Delphi / Cooligy LCSs: it was the OTHER way around: the early 2005 liquid-cooled systems are the ones that gave the G5 a bad fame of leakage, which used Panasonic radiators, which is the reason you almost never see 2.7GHz models that still live, while the late-2005 Quad replaced that with Delphi ones (both version 1 and 2).
Both version 1 and 2 are extremely reliable, which is why so many Quads still exist today (my own included), and most existant 2.7GHz G5 owners today, who are already so few, saved their machines precisely by replacing the faulty Panasonic LCS one with a Delphi one (same one found in the Quads).
People debate which version (1 or 2) is better, too, but there’s no existent reliable report so far. But it’s speculated version 2, as the numbering suggests, is a revision for even further reliability (perhaps by evening out the cooling for each processor contained by having 2 pipes).
donots2006 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 38
過去 30 日: 197
今までの合計 127,085
