メインコンテンツにスキップ
Porter-Cable PCC710B Eccentric Shaft Replacement
必要な工具と部品
  1. Porter-Cable PCC710B Eccentric Shaft Replacement, Lever assembly: 手順 1、 1の画像 1
    • Place the tool on its side so the orange and white warning label barcodes are facing up.
    • The lever and battery base of the tool should point toward you.
  2. Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 2、 3の画像 1 Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 2、 3の画像 2 Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 2、 3の画像 3
    • Use a 5.5 mm nut driver to unscrew the Hex nut.
    • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
  3. Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 3、 1の画像 1
    • Flip the tool over and remove the black screw holding the tool together.
    • Get a good grip on the screw by using pliers to pull the screw out of the tool.
  4. Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 4、 3の画像 1 Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 4、 3の画像 2 Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 4、 3の画像 3
    • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
    • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
  5. Porter-Cable PCC710B Eccentric Shaft Replacement, Housing: 手順 5、 3の画像 1 Porter-Cable PCC710B Eccentric Shaft Replacement, Housing: 手順 5、 3の画像 2 Porter-Cable PCC710B Eccentric Shaft Replacement, Housing: 手順 5、 3の画像 3
    • Lay the tool on its side so that the grey and orange warning labels are facing up upwards.
    • Use the JIS #1 screwdriver to remove the 10 screws holding the tool together.
  6. Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 6、 3の画像 1 Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 6、 3の画像 2 Porter-Cable PCC710B Eccentric Shaft Replacement: 手順 6、 3の画像 3
    • Lift the case off to access the internals of the tool.
  7. Porter-Cable PCC710B Eccentric Shaft Replacement, Spindle assembly: 手順 7、 3の画像 1 Porter-Cable PCC710B Eccentric Shaft Replacement, Spindle assembly: 手順 7、 3の画像 2 Porter-Cable PCC710B Eccentric Shaft Replacement, Spindle assembly: 手順 7、 3の画像 3
    • The outstretched arms of the spindle will be covered in grease - so grab a napkin to keep your hands clean!
    • Grasp the bottom of the spindle and pull it out towards you.
    • The spindle should come out easily. If not, lightly twist the object left and right while pulling it out.
    • You must grease the new spindle's arms before the install or else these parts will overheat and break. In addition, you'll have to maneuver the arms of the spindle around the head of the eccentric shaft. Finally, apply a light force to snap the spindle into place.
  8. Porter-Cable PCC710B Eccentric Shaft Replacement, Eccentric shaft: 手順 8、 3の画像 1 Porter-Cable PCC710B Eccentric Shaft Replacement, Eccentric shaft: 手順 8、 3の画像 2 Porter-Cable PCC710B Eccentric Shaft Replacement, Eccentric shaft: 手順 8、 3の画像 3
    • Gently pull the motor out of the case.
    • To remove the eccentric shaft simply pull it off of the motor.
    • When replacing the eccentric shaft, you must grease it before the install or else it'll overheat and break. The black fan shaped part of the eccentric shaft should slide onto the thin rod of the motor until it clicks securely.
終わりに
作成者
2人の作成者と共同で作成されました。
Alex Zapata
メンバー登録日: 09/19/22
665 ポイント
7のガイドは作成済み
チーム
Austin Community College, Team 13-3, Watkins Fall 2022 Austin Community College, Team 13-3, Watkins Fall 2022人のメンバー
AUSTINCC-WATKINS-F22S13G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 151
