メインコンテンツにスキップ
Polaroid PTAB7XC Screen Replacement
必要な工具と部品
  1. Polaroid PTAB7XC Screen Replacement, Screen: 手順 1、 2の画像 1 Polaroid PTAB7XC Screen Replacement, Screen: 手順 1、 2の画像 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver and by turning the screws counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Screen Replacement: 手順 2、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 2、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 2、 3の画像 3
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
    • The device is now free from the plastic casing.
    • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
  3. Polaroid PTAB7XC Screen Replacement: 手順 3、 2の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Wedge a plastic card beneath the battery unit.
    • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
    • Do not rupture the battery; it poses a serious safety hazard.
    • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
  4. Polaroid PTAB7XC Screen Replacement: 手順 4、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 4、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 4、 3の画像 3
    • Desolder the following components from the motherboard.
    • Desolder from the motherboard the red wire that connects to the speaker unit.
    • Desolder from the motherboard the black wire that connects to the speaker unit.
    • Desolder from the motherboard the gray wire that runs along the edge of the device.
    • The motherboard will now be detached from any wires connecting to the device except for those attached to the battery.
  5. Polaroid PTAB7XC Screen Replacement: 手順 5、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 5、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
    • Use a small opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
    • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
    • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
    • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
  6. Polaroid PTAB7XC Screen Replacement: 手順 6、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 6、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 6、 3の画像 3
    • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning them counterclockwise.
  7. Polaroid PTAB7XC Screen Replacement: 手順 7、 1の画像 1
    • Lift the motherboard and battery out of the device using your hands.
    • The back of the display and the speaker unit will now be visible and accessible
  8. Polaroid PTAB7XC Screen Replacement: 手順 8、 1の画像 1
    • Remove the 5mm screw that holds the speaker unit on to the display unit using a J000 screwdriver, turning the screws counterclockwise.
  9. Polaroid PTAB7XC Screen Replacement: 手順 9、 1の画像 1
    • Using thumb and forefinger, remove the speaker unit from the device
  10. Polaroid PTAB7XC Screen Replacement: 手順 10、 1の画像 1
    • Using a J000 Philips head screwdriver, remove the two 5mm screws that hold the display unit down at the bottom of the device, turning the screws counterclockwise.
  11. Polaroid PTAB7XC Screen Replacement: 手順 11、 1の画像 1
    • Lift the small black display protector that was between the screws and the display unit using your forefinger and thumb.
  12. Polaroid PTAB7XC Screen Replacement: 手順 12、 1の画像 1
    • Using both hands, lift up the device.
    • Using your fingers, push upward from below on the screen until the screen and display unit pop out of the black plastic frame.
    • The screen and display unit should now be separated from the plastic casing.
    • Set the screen and display unit screen-side down.
  13. Polaroid PTAB7XC Screen Replacement: 手順 13、 2の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 13、 2の画像 2
    • Wedge the large plastic opening tool into one of the notches on the edge of the screen and display unit.
    • Pry until a small tab pops out of the notch.
    • Repeat on every notch around the edge of the screen and display unit.
  14. Polaroid PTAB7XC Screen Replacement: 手順 14、 1の画像 1
    • Using your fingers, lift the display unit off of the screen.
    • The screen is now replaceable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Meg Lybbert
メンバー登録日: 10/08/15
649 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-2, Plummer Fall 2015 Eastern Washington University, Team 2-2, Plummer Fall 2015人のメンバー
EWU-PLUMMER-F15S2G2
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 564
