メインコンテンツにスキップ
PlayStation Power Supply Replacement
必要な工具と部品
  1. PlayStation Power Supply Replacement, Open the Console: 手順 1、 1の画像 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
  2. PlayStation Power Supply Replacement: 手順 2、 2の画像 1 PlayStation Power Supply Replacement: 手順 2、 2の画像 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Power Supply Replacement, Unplug the Power Supply: 手順 3、 2の画像 1 PlayStation Power Supply Replacement, Unplug the Power Supply: 手順 3、 2の画像 2
    • Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
  4. PlayStation Power Supply Replacement, Remove the Power Supply: 手順 4、 1の画像 1
    • Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
  5. PlayStation Power Supply Replacement: 手順 5、 2の画像 1 PlayStation Power Supply Replacement: 手順 5、 2の画像 2
    • Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply.
終わりに
24 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Craig Lloyd
メンバー登録日: 02/10/16
35,418 ポイント
82のガイドは作成済み
4 件のコメント
Since working with the power supply, it's wise to state in writing to disconnect the AC cord, in addition to showing it disconnected as you have.
Collin - 返信
Once I take out my power supply how do I fix the issue with the power supply
Tiago - 返信
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
kendofox - 返信
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 34
過去 30 日: 163
今までの合計 26,448
