メインコンテンツにスキップ
PlayStation Optical Drive Replacement
必要な工具と部品
  1. PlayStation Optical Drive Replacement, Open the Console: 手順 1、 1の画像 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
  2. PlayStation Optical Drive Replacement: 手順 2、 2の画像 1 PlayStation Optical Drive Replacement: 手順 2、 2の画像 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: 手順 3、 2の画像 1 PlayStation Optical Drive Replacement, Remove the Optical Drive: 手順 3、 2の画像 2
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
  4. PlayStation Optical Drive Replacement: 手順 4、 3の画像 1 PlayStation Optical Drive Replacement: 手順 4、 3の画像 2 PlayStation Optical Drive Replacement: 手順 4、 3の画像 3
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
  5. PlayStation Optical Drive Replacement: 手順 5、 2の画像 1 PlayStation Optical Drive Replacement: 手順 5、 2の画像 2
    • Lift the optical drive straight up to remove it.
終わりに
46 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Craig Lloyd
メンバー登録日: 02/10/16
35,480 ポイント
82のガイドは作成済み
4 件のコメント
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
leafybye - 返信
What about model SCPH-5501?
janis Nasuta - 返信
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
The invader 2 - 返信
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
John Reeves - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 130
過去 30 日: 511
今までの合計 62,559
