はじめに
The USB is an important part of the PlayStation Move controller. This guide will help you to remove and replace.
パーツ
パーツは指定されていません。
At the end of the circuit board, you should see a small silver connector port (this is the USB).
Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
ある他の人がこのガイドを完成しました。
