メインコンテンツにスキップ
PlayStation Controller Ports Replacement
必要な工具と部品
  1. PlayStation Controller Ports Replacement, Open the Console: 手順 1、 1の画像 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - 返信
  2. PlayStation Controller Ports Replacement: 手順 2、 2の画像 1 PlayStation Controller Ports Replacement: 手順 2、 2の画像 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Controller Ports Replacement, Remove the Controller Ports: 手順 3、 1の画像 1
    • Remove five Phillips #1 screws securing the metal shield to the controller ports:
    • Two 14 mm screws
    • Three 8 mm screws
  4. PlayStation Controller Ports Replacement: 手順 4、 2の画像 1 PlayStation Controller Ports Replacement: 手順 4、 2の画像 2
    • Lift the metal shield straight up to remove it.
  5. PlayStation Controller Ports Replacement: 手順 5、 2の画像 1 PlayStation Controller Ports Replacement: 手順 5、 2の画像 2
    • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
  6. PlayStation Controller Ports Replacement: 手順 6、 2の画像 1 PlayStation Controller Ports Replacement: 手順 6、 2の画像 2
    • Lift the controller ports straight up and out of the bottom case.
終わりに
11 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Craig Lloyd
メンバー登録日: 02/10/16
35,480 ポイント
82のガイドは作成済み
5 件のコメント
I try replacing the controller and still wouldn't play memory cards.
redevil19 - 返信
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - 返信
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
Daniel Prieto -
I'm having a weird issue, it will read in second do
Port but not the first. Changed controller port and still having the same issue
michael wise - 返信
The problem on mine is where I can’t use memory card slot 1 but Slot 2 works and is what I use but I would like to used slot 1 and have more than just a single memory card for playing games on it.
Travirus - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 37
過去 30 日: 156
今までの合計 26,414
