メインコンテンツにスキップ
PlayStation 2 Power Board Replacement
必要な工具と部品
  1. PlayStation 2 Power Board Replacement, Top Cover: 手順 1、 3の画像 1 PlayStation 2 Power Board Replacement, Top Cover: 手順 1、 3の画像 2 PlayStation 2 Power Board Replacement, Top Cover: 手順 1、 3の画像 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Power Board Replacement: 手順 2、 1の画像 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Power Board Replacement: 手順 3、 1の画像 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Power Board Replacement: 手順 4、 2の画像 1 PlayStation 2 Power Board Replacement: 手順 4、 2の画像 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
  5. PlayStation 2 Power Board Replacement, Power Board: 手順 5、 2の画像 1 PlayStation 2 Power Board Replacement, Power Board: 手順 5、 2の画像 2
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
  6. PlayStation 2 Power Board Replacement: 手順 6、 2の画像 1 PlayStation 2 Power Board Replacement: 手順 6、 2の画像 2
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
  7. PlayStation 2 Power Board Replacement: 手順 7、 2の画像 1 PlayStation 2 Power Board Replacement: 手順 7、 2の画像 2
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
  8. PlayStation 2 Power Board Replacement: 手順 8、 1の画像 1
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
  9. PlayStation 2 Power Board Replacement: 手順 9、 1の画像 1
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
  10. PlayStation 2 Power Board Replacement: 手順 10、 1の画像 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
  11. PlayStation 2 Power Board Replacement: 手順 11、 1の画像 1
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
  12. PlayStation 2 Power Board Replacement: 手順 12、 1の画像 1
    • Lift the expansion bay cage up off the motherboard assembly.
  13. PlayStation 2 Power Board Replacement: 手順 13、 2の画像 1 PlayStation 2 Power Board Replacement: 手順 13、 2の画像 2
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
終わりに
36 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
jwyoung
メンバー登録日: 11/04/09
2,809 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S19G1
4 メンバー
34のガイドは作成済み
5 件のコメント
Where do I buy the new Power Board?
chanceman75 - 返信
Where can you buy a new power board?
Logan Jorgensen - 返信
Can u replace the fuse.?
brincp - 返信
good news for us
VBlakeney - 返信
Merci beaucoup, vous êtes le meilleur et le meilleur
Rahef Love - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 72
過去 30 日: 364
今までの合計 39,543
