メインコンテンツにスキップ
Plantronics Voyager Legend Earpiece Replacement
必要な工具と部品
  1. Plantronics Voyager Legend Earpiece Replacement, Earpiece: 手順 1、 3の画像 1 Plantronics Voyager Legend Earpiece Replacement, Earpiece: 手順 1、 3の画像 2 Plantronics Voyager Legend Earpiece Replacement, Earpiece: 手順 1、 3の画像 3
    • Remove the soft, plastic earpiece.
    • Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
    • List the soft, plastic earpiece out of its position.
  2. Plantronics Voyager Legend Earpiece Replacement: 手順 2、 1の画像 1
    • Heat the earpiece assembly with a heat gun (a hair dryer will work if a heat gun is not available).
    • The heating softens the adhesive that holds the assembly together, and the assembly may need to be reheated to complete the dis-assembly process.
  3. Plantronics Voyager Legend Earpiece Replacement: 手順 3、 2の画像 1 Plantronics Voyager Legend Earpiece Replacement: 手順 3、 2の画像 2
    • The two snaps that combine with the adhesive to hold the assembly together are located in the neck of the earpiece unit.
  4. Plantronics Voyager Legend Earpiece Replacement: 手順 4、 2の画像 1 Plantronics Voyager Legend Earpiece Replacement: 手順 4、 2の画像 2
    • Remove the top half of the earpiece assembly.
    • Use the pointed end of a small, metal Spudger to loosen the two tabs that hold the earpiece assembly together.
    • While glue is soft and snaps are loosened, remove the entire top half of the earpiece housing.
  5. Plantronics Voyager Legend Earpiece Replacement: 手順 5、 3の画像 1 Plantronics Voyager Legend Earpiece Replacement: 手順 5、 3の画像 2 Plantronics Voyager Legend Earpiece Replacement: 手順 5、 3の画像 3
    • Remove the speaker housing.
    • With the copper backing plate displayed, use the pointed end of a small, metal Spudger to disassemble the speaker housing.
    • Using the pointed end of the small, metal Spudger, lift the copper, backing plate away from the speaker unit.
  6. Plantronics Voyager Legend Earpiece Replacement: 手順 6、 2の画像 1 Plantronics Voyager Legend Earpiece Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Use Precision Tweezers to remove the protective screen from the front of the speaker unit.
  7. Plantronics Voyager Legend Earpiece Replacement: 手順 7、 3の画像 1 Plantronics Voyager Legend Earpiece Replacement: 手順 7、 3の画像 2 Plantronics Voyager Legend Earpiece Replacement: 手順 7、 3の画像 3
    • Remove the speaker unit and solder a new unit in place.
    • When disconnecting leads, always disconnect as near as possible to the component being replaced, to allow room for reattachment.
    • Locate the leads that connect to the back of the speaker unit.
    • Disconnect the leads from the back of the speaker unit.
    • Remove the speaker unit, and replace by soldering the leads back into their correct locations.
    • Refer to the iFixit soldering guide for assistance with soldering.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Lewis Certain
メンバー登録日: 09/10/15
2,355 ポイント
3のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015人のメンバー
USFSM-STEWART-F15S1G2
5 メンバー
21のガイドは作成済み
1件のガイドコメント
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
albert einstein - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 35
今までの合計 17,058
