メインコンテンツにスキップ
Plantronics CS50 Headset Motherboard Replacement
必要な工具と部品
  1. Plantronics CS50 Headset Motherboard Replacement, Battery: 手順 1、 3の画像 1 Plantronics CS50 Headset Motherboard Replacement, Battery: 手順 1、 3の画像 2 Plantronics CS50 Headset Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Motherboard Replacement: 手順 2、 3の画像 1 Plantronics CS50 Headset Motherboard Replacement: 手順 2、 3の画像 2 Plantronics CS50 Headset Motherboard Replacement: 手順 2、 3の画像 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Plantronics CS50 Headset Motherboard Replacement, Microphone: 手順 3、 2の画像 1 Plantronics CS50 Headset Motherboard Replacement, Microphone: 手順 3、 2の画像 2
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. Plantronics CS50 Headset Motherboard Replacement: 手順 4、 2の画像 1 Plantronics CS50 Headset Motherboard Replacement: 手順 4、 2の画像 2
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  5. Plantronics CS50 Headset Motherboard Replacement: 手順 5、 2の画像 1 Plantronics CS50 Headset Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  6. Plantronics CS50 Headset Motherboard Replacement: 手順 6、 2の画像 1 Plantronics CS50 Headset Motherboard Replacement: 手順 6、 2の画像 2
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  7. Plantronics CS50 Headset Motherboard Replacement: 手順 7、 2の画像 1 Plantronics CS50 Headset Motherboard Replacement: 手順 7、 2の画像 2
    • Slowly separate the motherboard from the rest of the headset.
  8. Plantronics CS50 Headset Motherboard Replacement: 手順 8、 1の画像 1
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  9. Plantronics CS50 Headset Motherboard Replacement: 手順 9、 1の画像 1
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
  10. Plantronics CS50 Headset Motherboard Replacement, Motherboard: 手順 10、 3の画像 1 Plantronics CS50 Headset Motherboard Replacement, Motherboard: 手順 10、 3の画像 2 Plantronics CS50 Headset Motherboard Replacement, Motherboard: 手順 10、 3の画像 3
    • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
    • Using a plastic opening tool, prop open the edges.
    • Gently pull the black speaker casing up to remove it.
  11. Plantronics CS50 Headset Motherboard Replacement: 手順 11、 2の画像 1 Plantronics CS50 Headset Motherboard Replacement: 手順 11、 2の画像 2
    • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
    • The wires should come off as they are not soldered to the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Joe
メンバー登録日: 04/12/12
117 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G29
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,115
