この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The solenoid valve is critical to operation and if it breaks or becomes unreliable, the marker will not function. This guide shows how to replace the solenoid in the event of failure.
必要な工具と部品
Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Remove the two black hex bolts that connect the solenoid mount to the body.
Use the 5/64" Allen Key to rotate each screw counter clockwise.
3 件のコメント
Watis the price on etha solenoid, where can i get one , l ma staying in SA, myne is leaking ear,email ratgonefishing @gmail. Com
Hi my etha solenoid leaks ear,where do l get one,wats the price,i m staying in SA
Hello if it’s leaking try to lubricate your O-rings and switch out the filter, these can be very expensive from $55-$99 they don’t Make this model anymore so it’s very hard to find
Eddie -
