メインコンテンツにスキップ
Photive Rain Motherboard Replacement
必要な工具と部品
  1. Photive Rain Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Motherboard Replacement, Battery: 手順 3、 2の画像 1 Photive Rain Motherboard Replacement, Battery: 手順 3、 2の画像 2
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
  5. Photive Rain Motherboard Replacement, Speaker: 手順 5、 1の画像 1
    • Carefully remove the front panel from the device.
  6. Photive Rain Motherboard Replacement: 手順 6、 1の画像 1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  7. Photive Rain Motherboard Replacement: 手順 7、 2の画像 1 Photive Rain Motherboard Replacement: 手順 7、 2の画像 2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
  8. Photive Rain Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
  9. Photive Rain Motherboard Replacement: 手順 9、 1の画像 1
    • Pull the rubber away from the edge of the motherboard.
  10. Photive Rain Motherboard Replacement: 手順 10、 2の画像 1 Photive Rain Motherboard Replacement: 手順 10、 2の画像 2
    • Use the plastic opening tool to remove motherboard from device.
    • The second photograph displays a properly removed motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
abcdef ghijk
メンバー登録日: 02/15/16
723 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 1-4, Harley Spring 2016 IUPUI, Team 1-4, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S1G4
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 292
