メインコンテンツにスキップ
Photive Hydra USB Connector Replacement
必要な工具と部品
  1. Photive Hydra USB Connector Replacement, Face Plate and Back Plate: 手順 1、 1の画像 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra USB Connector Replacement: 手順 2、 2の画像 1 Photive Hydra USB Connector Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra USB Connector Replacement: 手順 3、 1の画像 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra USB Connector Replacement: 手順 4、 1の画像 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra USB Connector Replacement: 手順 5、 2の画像 1 Photive Hydra USB Connector Replacement: 手順 5、 2の画像 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra USB Connector Replacement, Battery (Prerequisite): 手順 6、 2の画像 1 Photive Hydra USB Connector Replacement, Battery (Prerequisite): 手順 6、 2の画像 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra USB Connector Replacement: 手順 7、 1の画像 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra USB Connector Replacement, USB Connector: 手順 8、 2の画像 1 Photive Hydra USB Connector Replacement, USB Connector: 手順 8、 2の画像 2
    • Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
  9. Photive Hydra USB Connector Replacement: 手順 9、 2の画像 1 Photive Hydra USB Connector Replacement: 手順 9、 2の画像 2
    • Pull the motherboard up and out to remove.
  10. Photive Hydra USB Connector Replacement: 手順 10、 1の画像 1
終わりに
作成者
3人の作成者と共同で作成されました。
Jose Muzaurieta
メンバー登録日: 02/09/16
120 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 11-3, Cheng Spring 2016 USF Tampa, Team 11-3, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S11G3
5 メンバー
6のガイドは作成済み
3件のガイドコメント
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Abraham Hernandez - 返信
Where can I purchase the usb
Sonia Lance - 返信
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
Sonia Lance - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 794
