メインコンテンツにスキップ
Philips Sonicare DiamondClean Motor Replacement
必要な工具と部品
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: 手順 1、 2の画像 1 Philips Sonicare DiamondClean Motor Replacement, Motor: 手順 1、 2の画像 2
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: 手順 2、 1の画像 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: 手順 3、 2の画像 1 Philips Sonicare DiamondClean Motor Replacement: 手順 3、 2の画像 2
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: 手順 4、 2の画像 1 Philips Sonicare DiamondClean Motor Replacement: 手順 4、 2の画像 2
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: 手順 5、 1の画像 1
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: 手順 6、 1の画像 1
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: 手順 7、 1の画像 1
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: 手順 8、 2の画像 1 Philips Sonicare DiamondClean Motor Replacement: 手順 8、 2の画像 2
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: 手順 9、 2の画像 1 Philips Sonicare DiamondClean Motor Replacement: 手順 9、 2の画像 2
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: 手順 10、 1の画像 1
    • Remove the motor and replace.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Caleb Watson
メンバー登録日: 09/16/20
512 ポイント
3のガイドは作成済み
3件のガイドコメント
Do you have a part number for the motor?
Suraj Daryapurkar - 返信
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - 返信
Thank you.
Are the motors generic? Any tips on purchasing them?
Thanks.
DaveQB - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 40
過去 30 日: 161
今までの合計 8,900
