メインコンテンツにスキップ
Philips Sonicare 9350 Battery Replacement
必要な工具と部品
  1. Philips Sonicare 9350 Battery Replacement, Head removal: 手順 1、 2の画像 1 Philips Sonicare 9350 Battery Replacement, Head removal: 手順 1、 2の画像 2
    • Remove the toothbrush head.
    • Use a screwdriver to pry gently around the bottom of the toothbrush.
  2. Philips Sonicare 9350 Battery Replacement, Remove the bottom: 手順 2、 3の画像 1 Philips Sonicare 9350 Battery Replacement, Remove the bottom: 手順 2、 3の画像 2 Philips Sonicare 9350 Battery Replacement, Remove the bottom: 手順 2、 3の画像 3
    • After the bottom of the toothbrush is pried loose, remove it from the base of the brush.
  3. Philips Sonicare 9350 Battery Replacement: 手順 3、 3の画像 1 Philips Sonicare 9350 Battery Replacement: 手順 3、 3の画像 2 Philips Sonicare 9350 Battery Replacement: 手順 3、 3の画像 3
    • Use a spudger to open the two clasps inside the toothbrush handle in a downward motion.
    • Turn the toothbrush upside down and push down on a hard surface—this will slide the toothbrush's internal body out.
  4. Philips Sonicare 9350 Battery Replacement, Extract the internals: 手順 4、 2の画像 1 Philips Sonicare 9350 Battery Replacement, Extract the internals: 手順 4、 2の画像 2
    • Pull out the internals of the toothbrush.
  5. Philips Sonicare 9350 Battery Replacement, Access the battery: 手順 5、 2の画像 1 Philips Sonicare 9350 Battery Replacement, Access the battery: 手順 5、 2の画像 2
    • Open the protective cover of the battery.
    • Check the battery model.
    • In this case, the model is a Sony 680mhA lithium battery.
  6. Philips Sonicare 9350 Battery Replacement, Desolder both terminals: 手順 6、 3の画像 1 Philips Sonicare 9350 Battery Replacement, Desolder both terminals: 手順 6、 3の画像 2 Philips Sonicare 9350 Battery Replacement, Desolder both terminals: 手順 6、 3の画像 3
    • Open the protection cover of the circuit board.
    • Find the welding points of the positive and negative electrodes of the battery and use the soldering iron to desolder.
    • The battery will fall off after desoldering as shown in the figure.
    • Be careful not to touch other parts of the circuit board when desoldering.
  7. Philips Sonicare 9350 Battery Replacement, Install a new battery: 手順 7、 3の画像 1 Philips Sonicare 9350 Battery Replacement, Install a new battery: 手順 7、 3の画像 2 Philips Sonicare 9350 Battery Replacement, Install a new battery: 手順 7、 3の画像 3
    • Use a spudger to pry the battery out at a 45 degree angle.
    • After successfully removing the battery, install the new battery using the reverse procedure.
    • Always use ESD safe tools when working on a circuit board or with batteries such as a nylon spudger.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Dongyi Lin
メンバー登録日: 05/10/21
273 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G16, O'Regan Summer 2021 York University, Team S1-G16, O'Regan Summer 2021人のメンバー
YORK-O'REGAN-SU21S1G16
1 メンバー
3のガイドは作成済み
1件のガイドコメント
All good advice and it works too. Ignore Philips advice that the battery is not replaceable. It is, with correct knowledge and understanding. Thanks for posting.
Shreds - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 233
今までの合計 11,416
