はじめに
The suppression capacitor in the Senseo Quadrante unfortunately often breaks down. The machine then no longer starts or the pump fails. The exchange is quite simple. You need a 0.47uF capacitor, class X2, at least 275 V, 22 mm pitch, which is easily available at any electronics store.
The repair goes quite similar to other devices
必要な工具と部品
Remove all attachments such as cup rack, pod holder and water tank.
The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
Work through the steps in reverse order to reassemble your device.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
shingleさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
Let op de + en - aansluiting van de condensator!
Dit type condensator heeft geen polariteit. Heb je de verkeerde condensator geïnstalleerd?
VauWeh -
