はじめに
The alarm speakers are to sound and notify if an issue or emergency is to occur to the patient currently in use of the ventilator of is a problem occurs within the ventilator itself.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Philips's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Philips
Replacing alarm speaker is discussed in:
- chapter 7.14 “Component Removal/Installation - Speakers” of service manual
- chapter 7.10 “Component Removal/Installation - Front Panel” of service manual
- chapter 7.9 “Component Removal/Installation - Separating the UI from the Base” of service manual
- chapter 7.8“Component Removal/Installation - Motor Controller (MC) PCBA” of service manual
- chapter 7.4 “Component Removal/Installation - Top Cover” of service manual
必要な工具と部品
step 1 Remove MC PCBA
Remove top cover (top cover guide here)
Remove the screws and wing nuts that attach the MC PCBA to the PCBA brackets.
Loosen the captive screws that attach the capacitor bracket to the base.
Disconnect cables: • Blower cable • Fan cable • DA-MC ribbon cable
Gently pull MC PCBA up from its connection on the CPU PCBA, then disconnect speaker #1 cable.
Remove PCBA brackets. To reinstall, follow the steps above in reverse order
step 2 separate the UI from the base
Remove MC PCBA (step 1)
Disconnect cables: • LCD cable from PM PCBA. • LCD cable ground wires from the ground terminal. • LCD tray ground wires from the ground terminal. • UI cable (ribbon cable) from the PM PCBA.
Loosen the captive screw that attaches the UI retainer to the UI.
Slide retainer up, then remove UI from base.
step 3 remove the front panel
Separate UI from base (step 2)
Remove hose clamp and boot that attach blower to the gas outlet.
Remove the tubing from the barbed fittings inside the front panel.
Disconnect gas outlet and proximal port ground wires from the base.
Remove the screws that attach the front panel to the base and side walls.
step 4 remove the alarm speakers
Remove front panel (step 3)
Disconnect speaker #2 from the power management (PM) PCBA. (Speaker #1 is disconnected when the MC PCBA is disconnected.)
Remove the screw and washer that attaches each speaker to the base.
Insert new speaker in place of old one
Follow step 4 in reverse order to install speaker.
step 5 reinstalling
Follow step 3 in reverse order to reinstall the front panel.
Follow step 2 in reverse order to reinstall the UI to the base.
Follow step 1 in reverse order to reinstall the MC PCBA.
Follow the Top Cover Guide in reverse order to reinstall.
