はじめに
This guide will lead users through the process of replacing a faulty touch screen. This may be required if the touch screen is unresponsive or does not turn on.
必要な工具と部品
Remove the top by lifting it upwards and setting it down.
Hi, I cannot lift the top half because it's blocked by the exhaust vent. Any step that I am missing?
Remove the back panel from the touch screen motherboard by popping the tabs off using the nylon spudger.
2 の人々がこのガイドを完成させました。
