メインコンテンツにスキップ
Pentax ZX-5n Exposure Compensation Dial Replacement
必要な工具と部品
  1. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove back cover: 手順 1、 1の画像 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove bottom cover: 手順 2、 1の画像 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove left front cover: 手順 3、 1の画像 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove front cover: 手順 4、 2の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove front cover: 手順 4、 2の画像 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove right front cover: 手順 5、 1の画像 1
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove eye cup: 手順 6、 1の画像 1
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Exposure Compensation Dial Replacement, Unscrew top cover: 手順 7、 3の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Unscrew top cover: 手順 7、 3の画像 2 Pentax ZX-5n Exposure Compensation Dial Replacement, Unscrew top cover: 手順 7、 3の画像 3
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Exposure Compensation Dial Replacement, Lift top cover: 手順 8、 1の画像 1
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Exposure Compensation Dial Replacement, Release top cover: 手順 9、 2の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Release top cover: 手順 9、 2の画像 2
    • De-solder the green, blue, brown and black wires from the flash PCB.
    • De-solder the black wire.
    • Pull out slack in the black wire so you can comfortably work on the underside of the top cover.
  10. Pentax ZX-5n Exposure Compensation Dial Replacement, Set exposure compensation: 手順 10、 1の画像 1
    • Set the exposure compensation dial to '0'.
  11. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove screws: 手順 11、 1の画像 1
    • Remove two #00 screws
    • Be careful not to damage the feeler contacts from the drive mode switch throughout the repair. There are delicate and easily bent.
  12. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove contact PCB: 手順 12、 2の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove contact PCB: 手順 12、 2の画像 2
    • Remove the contact PCB.
    • There is a metal plate underneath that may stick to the PCB.
  13. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove dial: 手順 13、 1の画像 1
    • Slide the exposure compensation dial out of the top cover.
    • If the dial was not set to '0' in Step 10, the knob will not slide out. Turning the knob at this stage could damage the detent spring.
  14. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove detent components: 手順 14、 2の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove detent components: 手順 14、 2の画像 2
    • Remove the ball bearing from the inside of the dial.
    • Remove the detent spring from the top cover.
  15. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove c-clip: 手順 15、 1の画像 1
    • Remove the small plastic c-clip on the end of the shaft.
    • Place your finger over the c-clip whenever you are working with it to prevent it from unexpectedly flying away.
  16. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove inner components: 手順 16、 3の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove inner components: 手順 16、 3の画像 2 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove inner components: 手順 16、 3の画像 3
    • Remove the lock button.
    • Remove the lock actuator.
    • Remove the lock spring.
  17. Pentax ZX-5n Exposure Compensation Dial Replacement, Reassembly notes: 手順 17、 2の画像 1 Pentax ZX-5n Exposure Compensation Dial Replacement, Reassembly notes: 手順 17、 2の画像 2
    • Use tape to hold components in place when reassembling the lock button and installing the dial.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Sam Gustafson
メンバー登録日: 09/01/22
3,350 ポイント
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 9
今までの合計 191
