メインコンテンツにスキップ
Pentax Optio WG-2 Battery Compartment Door Replacement
必要な工具と部品
  1. 注意: 手順 1-6 は、作業進行中としてマークされている ガイド から引用されています。
    Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: 手順 1、 2の画像 1 Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: 手順 1、 2の画像 2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 2、 1の画像 1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 3、 1の画像 1
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 4、 3の画像 1 Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 4、 3の画像 2 Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 4、 3の画像 3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 5、 1の画像 1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Battery Compartment Door Replacement: 手順 6、 1の画像 1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: 手順 7、 3の画像 1 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: 手順 7、 3の画像 2 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: 手順 7、 3の画像 3
    • Lift the cover as you normally would if replacing battery.
    • Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
    • There is a pin (3/4 of an inch long) that attaches the cover to the camera and it will come loose when the cover is removed.
終わりに
作成者
7人の作成者と共同で作成されました。
Matthew Bessette
メンバー登録日: 03/04/16
658 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 UMass Dartmouth, Team 6-7, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S6G7
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 12
今までの合計 765
