メインコンテンツにスキップ
Pebble Time Steel Battery Replacement
必要な工具と部品
  1. Pebble Time Steel Battery Replacement, Screen Cover: 手順 1、 1の画像 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Steel Battery Replacement: 手順 2、 2の画像 1 Pebble Time Steel Battery Replacement: 手順 2、 2の画像 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Steel Battery Replacement: 手順 3、 1の画像 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Steel Battery Replacement: 手順 4、 1の画像 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Steel Battery Replacement, Screen: 手順 5、 1の画像 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Steel Battery Replacement: 手順 6、 1の画像 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Steel Battery Replacement: 手順 7、 3の画像 1 Pebble Time Steel Battery Replacement: 手順 7、 3の画像 2 Pebble Time Steel Battery Replacement: 手順 7、 3の画像 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Steel Battery Replacement, Circuit Board: 手順 8、 1の画像 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Steel Battery Replacement: 手順 9、 1の画像 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Steel Battery Replacement: 手順 10、 3の画像 1 Pebble Time Steel Battery Replacement: 手順 10、 3の画像 2 Pebble Time Steel Battery Replacement: 手順 10、 3の画像 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Steel Battery Replacement: 手順 11、 1の画像 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Steel Battery Replacement: 手順 12、 2の画像 1 Pebble Time Steel Battery Replacement: 手順 12、 2の画像 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Steel Battery Replacement, Battery: 手順 13、 1の画像 1
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Steel Battery Replacement: 手順 14、 2の画像 1 Pebble Time Steel Battery Replacement: 手順 14、 2の画像 2
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Steel Battery Replacement: 手順 15、 2の画像 1 Pebble Time Steel Battery Replacement: 手順 15、 2の画像 2
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
  16. Pebble Time Steel Battery Replacement, Battery Flex Cable: 手順 16、 2の画像 1 Pebble Time Steel Battery Replacement, Battery Flex Cable: 手順 16、 2の画像 2
    • The original battery (note my lovely swollen one here) has a special flex cable attached to it that's soldered onto the battery - if you're up for it, desoldering this cable is probably the cleanest/easiest way to install.
    • There are two contact points (second photo) in the middle that need to be de-soldered and re-soldered, and as you can see they are quite small and fiddly, and you don't want to bridge the two because they're connected to a live battery unfortunately.
  17. Pebble Time Steel Battery Replacement, Trimming Battery Leads: 手順 17、 3の画像 1 Pebble Time Steel Battery Replacement, Trimming Battery Leads: 手順 17、 3の画像 2 Pebble Time Steel Battery Replacement, Trimming Battery Leads: 手順 17、 3の画像 3
    • Something that I didn't do, but is likely worth doing, is to trim the battery leads - you can see how much excess there is. This way there is less to tuck away and find space for when putting it back together. I also didn't get a photo of the battery just on its own, to show just how long the leads are, but they're about 3 or 4cm I'd say.
    • If you haven't potentially having a look at the Reddit thread linked in the Introduction is a good idea, as it gives you context for just how tight these batteries are to install, and how important selecting the right battery is, as well as knowing what you're getting yourself into!
  18. Pebble Time Steel Battery Replacement, Insulating Solder Points: 手順 18、 2の画像 1 Pebble Time Steel Battery Replacement, Insulating Solder Points: 手順 18、 2の画像 2
    • Once you've soldered the battery flex on, make sure to insulate your solder points else they'll ground out on the case, which wouldn't be good. Also, as you can probably see electrical tape is a bit too stiff for this application, so Kapton Tape is much better if you have it (or can get it).
    • I also didn't trim the leads, which in hindsight I should have. You can get away with the leads at full length, but you do have to be careful/strategic during reinstallation, so it's probably just simpler to trim the leads to about half their original length if you're being conservative, or even shorter if you're confident in your skills.
  19. Pebble Time Steel Battery Replacement, Replace Battery/Battery Flex Adhesive: 手順 19、 1の画像 1
    • Make sure to replace the adhesive under the battery, especially if your new battery comes with some, but also replace the adhesive under the battery flex cable - this helps it stay in place, and makes installation a lot easier. You can see in the picture the new adhesive (with the peel still on) that's ready for its new life in the case.
  20. Pebble Time Steel Battery Replacement, Put It Back Together: 手順 20、 1の画像 1
    • Now it's time to put it all together - for the most part, you can go back up this guide and use the steps in the reverse order as standard, however since I had excess lead length, I found it easier to install the Battery Flex Cable, then to install the Motherboard, and finally to tuck away all the excess lead and install the battery.
    • With the excess lead, I tucked this in slightly underneath and parallel to the inner left edge of the motherboard (where the two ribbon connectors are). The battery still fits reasonably well, but as you can see there is quite a lot of excess to store.
  21. Pebble Time Steel Battery Replacement, Button Cleaning/Adjusting: 手順 21、 2の画像 1 Pebble Time Steel Battery Replacement, Button Cleaning/Adjusting: 手順 21、 2の画像 2
    • If you haven't already, now is a really good time to check your buttons and clean them, to make sure they work properly whilst you're in there (before you put the board in preferably, I happened to only take the photos afterwards - writing guides is hard!)
    • You'll see on each of the buttons on the casing that there is a little circlip on each, that should sit in a detent - double check/verify that it's where it should be, as otherwise this can make the button hard to press and not return to its normal position as well. There's also a write up here on iFixit that's great for the buttons.
  22. Pebble Time Steel Battery Replacement, Test Before Final Reassembly: 手順 22、 1の画像 1
    • Before you adhesive everything back together, now is a good time to test that everything works as it should, and that your Pebble boots/vibrates etc. You can also see me reusing photos here, since I wasn't planning on making this guide when I replaced the battery in my watch - this just sort of happened later!
    • Also, installing that LCD Ribbon cable is a pain. Be prepared for that, and take your time as always.
    • If you haven't got a plastic spudger, I'd highly recommend you grab one and use it to press down on the connector to seat it, otherwise you can damage the connectors (I've done it before, learned the hard way).
  23. Pebble Time Steel Battery Replacement, A Quick Note On Adhesives: 手順 23、 1の画像 1
    • This seems to be something most people struggle with - what to attach the screen back on with. Tesa Tape is a good option, otherwise I actually used a spare LCD Adhesive set I had lying around (refer to next step).
    • One note is to not use Apple Watch Adhesives, as this was my original plan, which unfortunately didn't work.
    • My original plan was to grab some Apple Watch 5 Adhesive, and then to cut out the middle 1mm or so as you can see it's slightly too long. Unfortunately the adhesive is rubbish, and I also think it's likely a bit too thin for a Pebble - Tesa tape is a better option, and looks like what the factory use.
  24. Pebble Time Steel Battery Replacement, The DIY Is In Our DNA Adhesive Step: 手順 24、 2の画像 1 Pebble Time Steel Battery Replacement, The DIY Is In Our DNA Adhesive Step: 手順 24、 2の画像 2
    • This is the remnants of what I actually ended up using - LCD Screen Adhesive (Butyl/Tesa Tape)? Basically any LCD Screen Adhesive that has rounded corners will work, and you can just cut it to size. I went with a Pixel 6 Rear Adhesive set, and cut two long L shapes (2nd picture in the top right), and then just had them very slightly overlapping.
  25. Pebble Time Steel Battery Replacement, Adhesive Installed: 手順 25、 2の画像 1 Pebble Time Steel Battery Replacement, Adhesive Installed: 手順 25、 2の画像 2
    • Here's me having installed the adhesive. The fit wasn't quite perfect, but Tesa Tape is quite flexible, and so can be curved slightly once the backing is removed so that it fits in the channel. Tweezers are quite helpful for this however!
    • I would highly recommend putting the adhesive on the main frame (as opposed to the top cover, which was my first attempt), as it's much easier to align and get it in the right places. There are two nibs (top and right when looking down at the Pebble) that need to be adhesive free, as they clip into holes in the top cover for alignment.
  26. Pebble Time Steel Battery Replacement, Re-Test, Attach, And Celebrate!: 手順 26、 2の画像 1 Pebble Time Steel Battery Replacement, Re-Test, Attach, And Celebrate!: 手順 26、 2の画像 2
    • Re-test the LCD once you've attached the adhesive and before you seal it up, and then you're good to go! Once it's back together, I also like to heat up the Tesa Tape/device slightly and apply light pressure so that the tape gets tacky and does begin to stick both sides together consistently.
    • You can also see from the 2nd picture that the LCD/Cover do sit quite flush with Tesa Tape, and seem to seat/seal well, so hence why it's my preferred option (aside from the Pebble being designed for similar stuff).
    • But otherwise, you're done! Enjoy your new watch battery - also, a shameless Pebble Nav Me plug in there as well!
    • Make sure to calibrate your new battery by charging it fully, draining it fully, and then charging it until full again. And then, enjoy! (You must enjoy, that is an instruction, not a request).
終わりに
To reassemble your device, follow these instructions in reverse order (ish). In theory, if you've made is this far, you should be give or take done - enjoy your new(ish) Pebble!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Aadi Bhamidipati
メンバー登録日: 07/25/21
224 ポイント
1ガイドが承認済み
コメント 1 件
Thanks for the helpful guide! Managed to use the official ifixit battery replacement for the pebble time steel, and also managed to attach it directly to the battery PCB and fanangle it to fit. I’m not super proud of the bend in the flex PCB for the battery, but it’s working again so can’t complain.
Raymond Tu - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 102
今までの合計 354
