この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If you are unable to hear others when making calls and have ruled out other potential causes, you'll need to follow this guide to replace the earpiece speaker in your handset. Before we begin with this guide, please make sure that this is without a doubt the component that needs replacement. Getting to the earpiece speaker is not easy, and replacement will require soldering.
必要な工具と部品
Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
Now that the unit is separated from the front panel, proceed to remove the piece with the screen and buttons from the back panel.
