メインコンテンツにスキップ
Panasonic KX-TGE233 Earpiece Speaker Replacement
必要な工具と部品
  1. Panasonic KX-TGE233 Earpiece Speaker Replacement, Battery: 手順 1、 2の画像 1 Panasonic KX-TGE233 Earpiece Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Flip the handset over to expose the back panel, and slide the panel out to remove.
  2. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 2、 1の画像 1
    • Carefully remove the two batteries by lifting up from one end.
  3. Panasonic KX-TGE233 Earpiece Speaker Replacement, Handset Front Panel Assembly: 手順 3、 1の画像 1
    • Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
  4. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 4、 1の画像 1
    • Using a spudger, open the device by starting from the bottom and working your way to the top.
    • This will require some force, so be careful not to break any of the wires inside of the device.
  5. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 5、 1の画像 1
    • Once the back has been separated from the rest of the device, carefully place it to the side. Be careful not to completely remove it, however, as there are wires connecting the back to the handset.
  6. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 6、 1の画像 1
    • Using the same screwdriver as before, remove the Philips size #00 screw holding the motherboard in place.
  7. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 7、 1の画像 1
    • With the screw removed, the front panel assembly can be separated from the rest of the device.
  8. Panasonic KX-TGE233 Earpiece Speaker Replacement, Earpiece Speaker: 手順 8、 1の画像 1
    • Now that the unit is separated from the front panel, proceed to remove the piece with the screen and buttons from the back panel.
    • Be careful not to harm the wires connecting the back speaker.
  9. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 9、 1の画像 1
    • Remove the earpiece speaker from its resting spot on the front of the device. Be careful not to remove this speaker from the device entirely before moving to the next steps.
  10. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 10、 1の画像 1
    • The device should now be flipped over, as the wires connecting the earpiece speaker make contact on the back.
  11. Panasonic KX-TGE233 Earpiece Speaker Replacement: 手順 11、 1の画像 1
    • Use a soldering iron to loosen the soldering on the contact points. If heated properly, the contacts should be loose enough that the speaker can easily be removed.
    • For tips on how to solder, use the following guide: Technique: How To Solder and Desolder Connections
終わりに
作成者
2人の作成者と共同で作成されました。
Jesse Satterwhite
メンバー登録日: 02/11/16
682 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G2
5 メンバー
15のガイドは作成済み
コメント 1 件
But where do you get a replacement speaker? That seems to be the impossible task!
fvasnun1 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 2,863
