この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
A brief guide on how to replace the battery for your Palm V
必要な工具と部品
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Lay screen face down so the battery is facing upwards.
Cover the upper back portion of the device so the battery is the only exposed part.
3 の人々がこのガイドを完成させました。
