この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will walk you through the steps to remove the motherboard on a Palm T|X.
必要な工具と部品
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Use a soldering iron to disconnect the battery wires from the motherboard.
For soldering instructions, you can view the Soldering Guide.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
もう少しです!
終わりに
