メインコンテンツにスキップ
Palm TX Motherboard Replacement
必要な工具と部品
  1. Palm TX Motherboard Replacement, Back Panel: 手順 1、 2の画像 1 Palm TX Motherboard Replacement, Back Panel: 手順 1、 2の画像 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Motherboard Replacement: 手順 2、 1の画像 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Motherboard Replacement: 手順 3、 2の画像 1 Palm TX Motherboard Replacement: 手順 3、 2の画像 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Motherboard Replacement: 手順 4、 2の画像 1 Palm TX Motherboard Replacement: 手順 4、 2の画像 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Motherboard Replacement: 手順 5、 2の画像 1 Palm TX Motherboard Replacement: 手順 5、 2の画像 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Motherboard Replacement, Battery Pack: 手順 6、 2の画像 1 Palm TX Motherboard Replacement, Battery Pack: 手順 6、 2の画像 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Palm TX Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Motherboard Replacement: 手順 8、 2の画像 1 Palm TX Motherboard Replacement: 手順 8、 2の画像 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
終わりに
作成者
6人の作成者と共同で作成されました。
Spencer Lewson
メンバー登録日: 01/19/11
793 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S1G15
4 メンバー
7のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 3,460
