メインコンテンツにスキップ
Oster 16-Speed Blender Power Cord Replacement
必要な工具と部品
  1. Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: 手順 1、 2の画像 1 Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: 手順 1、 2の画像 2
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Power Cord Replacement: 手順 2、 2の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 2、 2の画像 2
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Power Cord Replacement: 手順 3、 3の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 3、 3の画像 2 Oster 16-Speed Blender Power Cord Replacement: 手順 3、 3の画像 3
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  4. Oster 16-Speed Blender Power Cord Replacement: 手順 4、 2の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 4、 2の画像 2
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Power Cord Replacement: 手順 5、 2の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 5、 2の画像 2
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Power Cord Replacement: 手順 6、 1の画像 1
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Power Cord Replacement: 手順 7、 3の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 7、 3の画像 2 Oster 16-Speed Blender Power Cord Replacement: 手順 7、 3の画像 3
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Power Cord Replacement: 手順 8、 3の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 8、 3の画像 2 Oster 16-Speed Blender Power Cord Replacement: 手順 8、 3の画像 3
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Power Cord Replacement: 手順 9、 2の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 9、 2の画像 2
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  10. Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 手順 10、 3の画像 1 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 手順 10、 3の画像 2 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 手順 10、 3の画像 3
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Power Cord Replacement: 手順 11、 2の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 11、 2の画像 2
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
  12. Oster 16-Speed Blender Power Cord Replacement: 手順 12、 3の画像 1 Oster 16-Speed Blender Power Cord Replacement: 手順 12、 3の画像 2 Oster 16-Speed Blender Power Cord Replacement: 手順 12、 3の画像 3
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
  13. Oster 16-Speed Blender Power Cord Replacement, Power Cord: 手順 13、 1の画像 1
    • You do not have to completely remove the circuit board to replace the power cord. You can, if desired, skip the steps of de-soldering the yellow wire, and the circuit board from the base.
    • De-solder the black wire from the circuit board, and then carefully remove the black wire.
    • Now you can solder on the new power cord.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dana
メンバー登録日: 04/14/14
773 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G37
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 32
今までの合計 3,160
