メインコンテンツにスキップ
Oster 16-Speed Blender Circuit Board Replacement
必要な工具と部品
  1. Oster 16-Speed Blender Circuit Board Replacement, Fan and Motor: 手順 1、 2の画像 1 Oster 16-Speed Blender Circuit Board Replacement, Fan and Motor: 手順 1、 2の画像 2
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Circuit Board Replacement: 手順 2、 2の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 2、 2の画像 2
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Circuit Board Replacement: 手順 3、 3の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 3、 3の画像 2 Oster 16-Speed Blender Circuit Board Replacement: 手順 3、 3の画像 3
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  4. Oster 16-Speed Blender Circuit Board Replacement: 手順 4、 2の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 4、 2の画像 2
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Circuit Board Replacement: 手順 5、 2の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 5、 2の画像 2
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Circuit Board Replacement: 手順 6、 1の画像 1
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Circuit Board Replacement: 手順 7、 3の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 7、 3の画像 2 Oster 16-Speed Blender Circuit Board Replacement: 手順 7、 3の画像 3
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Circuit Board Replacement: 手順 8、 3の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 8、 3の画像 2 Oster 16-Speed Blender Circuit Board Replacement: 手順 8、 3の画像 3
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Circuit Board Replacement: 手順 9、 2の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 9、 2の画像 2
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  10. Oster 16-Speed Blender Circuit Board Replacement, Circuit Board: 手順 10、 3の画像 1 Oster 16-Speed Blender Circuit Board Replacement, Circuit Board: 手順 10、 3の画像 2 Oster 16-Speed Blender Circuit Board Replacement, Circuit Board: 手順 10、 3の画像 3
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Circuit Board Replacement: 手順 11、 2の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 11、 2の画像 2
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
  12. Oster 16-Speed Blender Circuit Board Replacement: 手順 12、 3の画像 1 Oster 16-Speed Blender Circuit Board Replacement: 手順 12、 3の画像 2 Oster 16-Speed Blender Circuit Board Replacement: 手順 12、 3の画像 3
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
終わりに
Now your circuit board is ready to be replaced. To reassemble your device, follow these instructions in reverse order.
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dana
メンバー登録日: 04/14/14
818 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G37
4 メンバー
7のガイドは作成済み
11件のガイドコメント
So, a question. Where does the spring go? I was fixing one of these and the spring fell out and I never saw where it came from.
Seth Grady - 返信
inside 2 tubes that stick out opposite of each other just below the fan.
dbagarotti -
Spring goes on the one of the strips that slides back and forth....it has small end which goes in a small notched cavity of the plastic housing. Spring goes on that longer end of the stripe. See the picture in step 12...its popped out from the plastic housing.
Jignesh Rathod -
conoces el orden de las laminas del circuito de velocidades…? agradecere cualquier sugerencia…
juliogpe_cc - 返信
Awesome, this guide was really helpful in repairing my blender. Thumbs up for the author.
Okikiolu Jegede - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 138
今までの合計 7,115
