メインコンテンツにスキップ
Oral-B Black 7000 Induction Coil Replacement
必要な工具と部品
  1. Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: 手順 1、 3の画像 1 Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: 手順 1、 3の画像 2 Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: 手順 1、 3の画像 3
    • Use the charging station to remove the a small plastic plug from the end of the toothbrush by inserting the charging station into the end insert and twisting counter-clockwise by 90 degrees.
  2. Oral-B Black 7000 Induction Coil Replacement: 手順 2、 1の画像 1
    • Remove the end cap from the bottom of the toothbrush by prying it off with a spudger.
  3. Oral-B Black 7000 Induction Coil Replacement: 手順 3、 1の画像 1
    • Remove the top cap by using a spudger to pry the plastic ring off of the toothbrush frame.
  4. Oral-B Black 7000 Induction Coil Replacement: 手順 4、 2の画像 1 Oral-B Black 7000 Induction Coil Replacement: 手順 4、 2の画像 2
    • Use a spudger to loosen the two plastic tabs next to the induction coil that secure the internal assembly to the frame.
    • Push on the rotating head in order to pop the assembly out of the black plastic casing.
    • You can also use a spudger to leverage the assembly out, but this may break the copper wire connected to the induction coil, so be careful.
  5. Oral-B Black 7000 Induction Coil Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Unwrap the ends of the wires from the white plastic pegs using a pair of tweezers.
    • Each wire end is wrapped around the peg 3-4 times.
  6. Oral-B Black 7000 Induction Coil Replacement: 手順 6、 1の画像 1
    • Melt the solder at the two pads on either side of the top of the motherboard. This will require a high heat soldering iron. Remove the wire from the solder pads using tweezers once the solder melts.
  7. Oral-B Black 7000 Induction Coil Replacement: 手順 7、 1の画像 1
    • Remove the induction coil by pulling the plastic tabs out of their keepers.
    • A spudger can be used to remove the plastic tabs from their keepers if neccessary.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Rachel Surridge
メンバー登録日: 11/06/17
376 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G1, Harley Fall 2017 IUPUI, Team S1-G1, Harley Fall 2017人のメンバー
IUPUI-HARLEY-F17S1G1
3 メンバー
16のガイドは作成済み
3 件のコメント
bonjour, ou puis je trouver une nouvelle bobine d’induction ou puis je remplacer simplement le fil de cuivre
Geoffrey Sacré - 返信
juste une précision pour sortir l’intérieur de la brosse du manche il faut appuyez sur les deux pattes plastique en bas près de la boucle d’induction
on voit une des pattes a l’étape 5
Geoffrey Sacré - 返信
Woher bekomme ich denn eine neue ladespule?
Franz Leichsenring - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 42
過去 30 日: 173
今までの合計 5,957
