メインコンテンツにスキップ
Opening the Siemens Surpresso Compact
必要な工具と部品
  1. Opening the Siemens Surpresso Compact, Opening the Siemens Surpresso Compact: 手順 1、 1の画像 1
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Opening the Siemens Surpresso Compact: 手順 2、 1の画像 1
    • Remove the two Torx T10 screws on the top.
  3. Opening the Siemens Surpresso Compact: 手順 3、 2の画像 1 Opening the Siemens Surpresso Compact: 手順 3、 2の画像 2
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Opening the Siemens Surpresso Compact: 手順 4、 2の画像 1 Opening the Siemens Surpresso Compact: 手順 4、 2の画像 2
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Opening the Siemens Surpresso Compact: 手順 5、 2の画像 1 Opening the Siemens Surpresso Compact: 手順 5、 2の画像 2
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Opening the Siemens Surpresso Compact: 手順 6、 1の画像 1
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
終わりに
To reassemble your device, follow the steps in reverse order.
15 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
VauWeh
メンバー登録日: 10/19/15
202,869 ポイント
246のガイドは作成済み
チーム
Repair is War on Entropy Repair is War on Entropy人のメンバー
Community
25 メンバー
1,110のガイドは作成済み
3 件のコメント
Sehr gut beschrieben und bebildert, danach kann man gut arbeiten, Danke.
h.kornetzki - 返信
Wie bekomme ich den vorderen Gehäusedeckel ab? Ich muss den Dampfschalter tauschen.
sabine.gorski - 返信
Hab ich noch nie gemacht. Sicher muss der Auslauf weg: Siemens Surpresso Compact Kaffeeauslaufverteiler austauschen, suche dann die Schrauben und Rasten. Gutes Gelingen, wir würden uns freuen, wenn du das für iFixit dokumentierst!
VauWeh -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 68
今までの合計 7,386
