メインコンテンツにスキップ
Oontz Angle 3 ULTRA Micro USB Port Replacement
必要な工具と部品
  1. Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: 手順 1、 3の画像 1 Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: 手順 1、 3の画像 2 Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 2、 3の画像 1 Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 2、 3の画像 2 Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 2、 3の画像 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 3、 3の画像 1 Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 3、 3の画像 2 Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 3、 3の画像 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 4、 3の画像 1 Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 4、 3の画像 2 Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 4、 3の画像 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Micro USB Port Replacement, Micro USB Port: 手順 5、 1の画像 1
    • Gently push the ports away from the speaker enclosure with the spudger to free the motherboard.
  6. Oontz Angle 3 ULTRA Micro USB Port Replacement: 手順 6、 1の画像 1
    • With your solderwick and soldering iron, remove the solder at each point, and gently pull the micro USB port away from the motherboard with the tweezers.
    • More information on soldering, please read the How to Solder and Desolder Connections Guide.
終わりに
作成者
1人の作成者と共同作成されました。
Ian
メンバー登録日: 01/16/20
383 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 29
今までの合計 2,651
