メインコンテンツにスキップ
Oontz Angle 3 ULTRA Driver Replacement
必要な工具と部品
  1. Oontz Angle 3 ULTRA Driver Replacement, Back Panel: 手順 1、 3の画像 1 Oontz Angle 3 ULTRA Driver Replacement, Back Panel: 手順 1、 3の画像 2 Oontz Angle 3 ULTRA Driver Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Driver Replacement: 手順 2、 3の画像 1 Oontz Angle 3 ULTRA Driver Replacement: 手順 2、 3の画像 2 Oontz Angle 3 ULTRA Driver Replacement: 手順 2、 3の画像 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Driver Replacement: 手順 3、 3の画像 1 Oontz Angle 3 ULTRA Driver Replacement: 手順 3、 3の画像 2 Oontz Angle 3 ULTRA Driver Replacement: 手順 3、 3の画像 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Driver Replacement: 手順 4、 3の画像 1 Oontz Angle 3 ULTRA Driver Replacement: 手順 4、 3の画像 2 Oontz Angle 3 ULTRA Driver Replacement: 手順 4、 3の画像 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Driver Replacement, Driver: 手順 5、 1の画像 1
    • Insert the Jimmy into the gap between the speaker's grill and the plastic enclosure.
    • Work the Jimmy around the gap to free it from the speaker enclosure.
    • The grill edges are sharp. Be careful and patient when performing this step to avoid injuring yourself.
  6. Oontz Angle 3 ULTRA Driver Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
    • Locate the wires connecting to the driver. There will be a red wire connected to the driver’s positive terminal, and a black wire connected to the driver’s negative terminal.
    • During reassembly, it is important to orient the wires properly to avoid damage to the speaker and new drivers.
    • With your soldering iron and solder sucker, remove the solder connecting the wires to each terminal, and then gently pull the wires away from the terminals to free them.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections Guide.
  7. Oontz Angle 3 ULTRA Driver Replacement: 手順 7、 2の画像 1 Oontz Angle 3 ULTRA Driver Replacement: 手順 7、 2の画像 2
    • Remove the eight screws with the Phillips #0 screwdriver.
    • Gently push the driver from the rear out of the enclosure to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ian
メンバー登録日: 01/16/20
383 ポイント
3のガイドは作成済み
3 件のコメント
Where can i purchase replacement speaker
John Benedict Sumallo - 返信
reference of speakers of Oontz Angle 3 ULTRA U12A pls to replacement speaker
Luis Calderon - 返信
any luck on replacement speakers?
Tirso Ramirez - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 916
